fuel sender stuck after fuel filter replacement - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-19-2011, 05:50 PM Thread Starter
Date registered: Jan 2011
Vehicle: 2006 Mercedes ML500
I have a 2006 ML500 with 52K miles on it, purchased in late 2005. I just had my dealership replace the fuel filter as a maintenance item with a 5 year recommendation - a pricey $600ish. No problem encountered, just regular maintenance. Less than one week later, same tank of fuel, my car stalled on the highway and I was towed into the closest dealership. They determined that although my fuel gauge read 1/4 tank, the tanks were actually bone dry due to a "stuck" fuel level sender -- another $745 bill plus $80 towing. My fuel gauge was always accurate before, never had a jumpy needle or anything close. My question: could the first dealership have damaged the "level sender" when they replaced the fuel filter? do they pressurize the the system? what could they have done wrong to cause this? Common sense tells me something they did caused this secondary problem. How can I prove it? Thanks for any insight that will help me prove my case. Debbie
mahandl is offline
post #2 of 2 (permalink) Old 01-19-2011, 10:48 PM
mbvis's Avatar
Date registered: Jan 2010
Vehicle: 99 E430, 01 E430 Sport, 00 SL500
Quoted: 2 Post(s)
Some old discussion about the fuel sender of the same ML model:
Benzworld.org - Mercedes-Benz Discussion Forum - Search Results
It's a known "common" problem. What happened to your ML might be coincidental but it came right after the service so it might not be coincidental at all.
Talk to the first dealer, tell them about the fuel sender problem after their service without pointing any finger at anyone or anything, hear their explanation then plot your next move from there.
mbvis is offline
    Fixing the fuel gauge (not fuel sender) necromancer W124 E,CE,D,TD Class 12 01-14-2013 07:05 PM
    Replacement fuel level sender 380SLC Sideskraft R/C107 SL/SLC Class 3 07-11-2010 09:47 PM
    Fuel Sender Fel Apart in Fuel Tank... to loss W123 E,CE,D,CD,TD,TE Class 1 03-08-2010 07:07 PM
    fuel sender/pump replacement roberhelfrick W163 M-Class 3 03-09-2007 07:43 AM
    W202 Fuel Sender Unit Replacement. JuryC W202 C-Class 0 08-31-2003 11:06 PM
