86 560 SEL fast idle - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 01-19-2011, 02:41 PM Thread Starter
Date registered: Jan 2011
Vehicle: 1997 E300 Diesel
My 1986 560 SEL has just recently started idling at 1700 rpm and it starts very hard in the morning. I've been told that it might be the overload protection relay fuse, but the fuse looks fine and when I pulled the entire relay out while the car was running, nothing changed. I was also told by a mercedes tech that it could be an idle control valve; again, I pulled the power from the valve while the car was running and nothing changed. Could this mean that both the valve and the relay are bad?
Any suggestions would be greatly appreciated, thank you.
saphiro is offline
    Rough idle, misfire W126 560 SEL areces.cf W126 S,SE,SEC,SEL,SD,SDL Class 8 09-12-2011 05:22 AM
    88 560 SEL hesitation/rough idle/fresh air pump jgilbert66 W126 S,SE,SEC,SEL,SD,SDL Class 13 10-15-2008 08:45 AM
    Idle speed for 87 560 SEL lester44 W126 S,SE,SEC,SEL,SD,SDL Class 1 03-11-2005 05:20 PM
    High idle after hosing down engine compartment on 89 560 SEL TBonus W126 S,SE,SEC,SEL,SD,SDL Class 12 02-25-2004 04:15 AM
    1989 560 SEC Fast Idle Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 1 02-14-2001 03:41 AM
