Mercedes wont start first time - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-18-2011, 09:12 AM Thread Starter
Date registered: Jan 2011
My 1994 Mercedes E420 won't start the first time I try it. But it will start second time.. sometimes third.. Any suggestions???
jml042 is offline
post #2 of 2 (permalink) Old 01-18-2011, 11:42 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
The fuel isn't there the 1st time.
Check the components designed to maintain fuel pressure at the "rail" after engine is stopped. Usually called "accumulator" or "pressure regulator."
A useful test might be to cycle the ignition switch on/off a couple/three times before attempting a start. I bet it will start 1st time if you do that.
Turning on ignition provides only a 1-3 second run of fuel pump and then it shuts off awaiting signal engine has started.
Kent Christensen
'07 GL320CDI
lkchris is offline
    Mercedes 400E wont start Uninformed General Mercedes-Benz 0 08-07-2010 09:58 AM
    89' 260e mercedes wont start ? 89'mercedes260e W201 190-Class 3 01-17-2010 08:41 AM
    Mercedes Hit on Side, Wont Start ...Help PLEASE TonyCLK320 C208/A208 CLK-Class 7 05-21-2009 11:38 AM
    mercedes c220 wont start charlie_22 General Mercedes-Benz 3 02-05-2009 10:43 AM
    Help 300d Wont start unless block heater is plugged in, Even in summer time LS1 W123 E,CE,D,CD,TD,TE Class 8 11-24-2008 10:15 AM
