Cold start running problem - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 01-13-2011, 05:43 PM Thread Starter
Date registered: Dec 2008
I have a C320, 2001 which fails to restart after initial starting. I start it up cold and drive about 2-3 miles , shut it off , then I have to wait about 20-30 minutes before for it will restart. Any help with this problem. The battery is not even 3 years old
dalefkel is offline
post #2 of 4 (permalink) Old 01-16-2011, 07:47 AM
Date registered: Jan 2007
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
crank sensor. they usually fail when hot.
Streetglower is offline
post #3 of 4 (permalink) Old 01-16-2011, 09:33 PM
Date registered: Nov 2010
Two things could cause this problem. Either the Fuel pump has finally taken a dump or the fuel filter needs to be changed out.
jackjroadster is offline
post #4 of 4 (permalink) Old 01-17-2011, 12:16 PM
Musikmann's Avatar
Quoted: 5 Post(s)
Ditto to CPS/KPS aka crankshaft position sensor. CPS is also used to abbreviate the camshaft position sensor which adds to the confusion. Your symptoms sound very much like a lot of other people who have experienced a similar problem.
Musikmann is offline
    Cold Start Running rennwerkes W210 E50 AMG, E55 AMG 2 06-18-2009 05:14 PM
    Newbie with 420 SEC weird cold running problem big_treacle W126 S,SE,SEC,SEL,SD,SDL Class 6 01-31-2008 03:53 AM
    Running rich on driver's side bank, surging at cold start, no acceleration beazo General Mercedes-Benz 2 08-16-2005 11:52 AM
    280E: Will Run When Activating Starter; Just running on cold start? How do I test system? GermanCarNut W123 E,CE,D,CD,TD,TE Class 6 01-24-2004 06:10 PM
    Update on my cold start studdering problem - problem fixed? Douglas-Indianapolis R170 SLK-Class 4 04-25-2001 04:28 AM
