380SL HUGE smoke going downhill only - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 01-11-2011, 10:15 AM Thread Starter
Date registered: Jan 2011
Vehicle: 1985 380SL
I purchased an '85 380 SL 4 years ago. It drove pretty well and passed SMOG here in CA. All was well until I drove DOWN the hill from my home the next morning. The smoke cloud was bigger than anything James Bond had in his Aston. The trans shift was also sluggish, so I put an additive in and that cured the shift problem. The additive had a unique odor. From time to time, I smell the additive in the passenger compartment. O.K., that is the background info..
I have had the valve covers off and there is no oil pooling along the valve train. I did notice indication of worn valve guides. I have run the car (gently) with only 3.5 quarts of oil to see if crank splash from oil getting deep at the front of the pan, while going down hill, was the problem. No change. Hill angle needs to exceed 25 degrees down to have the problem. GOING DOWNHILL (steep) IS THE ONLY TIME THERE IS A SMOKE PROBLEM. It seems it's time overhaul the heads, but wonder if there is more wrong before going to that time & expense. I'd hate for the problem to be bottom end too, or that be the real problem. The car has 172K. It has the X2 timing chains, not sure if that indicates previous head overhaul. The car virtually sat for 5 years prior to my starting it in the previous owner's garage. It is gorgeous and I want to get it running right.
I live in Los Angeles and would like to get the opinion of an expert, someone who will take the time to diagnose this problem correctly, then proceed with the repair. I have not found that shop yet.
I hope the right person reads this.
saabconvert is offline
post #2 of 4 (permalink) Old 01-11-2011, 04:31 PM
eric242340's Avatar
Quoted: 283 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
At the bottom of the page you will find forum jump, click on this and view all the available sub forums.
eric242340 is online now
post #3 of 4 (permalink) Old 01-13-2011, 11:20 AM
Vehicle: 2004 SLK230, 1992 E300, 1992 E400
Definitely sounds (looks!) like valve guides/seals. If it sat for 5 years, the valve seals have probably deterioated (sp) due to NO oil for so long (the neoprene or whatever is used is probably in little, crumbly, pieces in the bottom of your oil pan (let's HOPE that's where they wound up..............).
Pull off the valve covers and have a lookey.
larrypayne is offline
post #4 of 4 (permalink) Old 01-14-2011, 12:13 AM Thread Starter
Vehicle: 1985 380SL
Thank you, Larry. I've had the valve covers off and the seals are still there. No chunks missing, but they may very well have shrunk and hardened. Guess if I replace the seals on #1 and #8, I'd stand a shot of knowing if the problem is top end, or not. I finally have a bit of time to give that a shot.
    weird HUGE puffs of blue smoke-sometimes pointydog W126 S,SE,SEC,SEL,SD,SDL Class 17 04-28-2012 10:33 AM
    White smoke facing downhill while stopped mulewright W126 S,SE,SEC,SEL,SD,SDL Class 9 09-13-2010 04:58 PM
    huge white gray smoke 81 300D non turbo adysor W123 E,CE,D,CD,TD,TE Class 29 04-21-2010 02:31 PM
    Engine heavy smoke downhill lavor W126 S,SE,SEC,SEL,SD,SDL Class 10 09-15-2009 09:38 AM
    DEAR GOD! blue smoke from a 560SEL after prolonged downhill runningl shrimpton W126 S,SE,SEC,SEL,SD,SDL Class 20 04-04-2009 09:51 PM
