1996 E320 misfire problems - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 01-09-2011, 09:49 AM Thread Starter
Date registered: Jan 2011
Hello, i am new to the forum as well as the car! I was trying to sell it and when the person took it for a test drive, the check engine light came on as well as the check electronics. It started to sputter and lose power, barely made it back. It has been running like a charm. I set in it and started it and it sounded awful, and for a brief moment it said battery charging? We have cleaned the MAF and took it an auto store to find out what the codes were and they stated that it was in need of a tune up, plugs and wires. We changed out plugs, not wires yet, sounds better, but still rough. I read a post on here that said this
"today i changed the plugs to e3 spark plugs, flipped the coils and cleaned the maf with maf spray. what a huge difference!!! the car runs great!!! lets see if this was the problem and if it keeps running like a champion. my fingers are crossed.
cjshade thanks for your help!!!
What does he mean by he flipped the coils? (did he change them or move them arround etc.) I am low on money, this is why selling the car, so any advice would be appreciated.
Thanks
beamkim is offline
post #2 of 4 (permalink) Old 01-09-2011, 11:09 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 86 Post(s)
What were the codes? He means that if there is a misfire on a specific cylinder, you can switch the ignition module with one that is on a cylinder that is not showing a misfire. If you get a misfire on the other cylinder, then there is a chance the ignition module is faulty.
Mike
Michael Pillay is offline
post #3 of 4 (permalink) Old 01-09-2011, 11:32 AM Thread Starter
1996 E320 misfire
They told him that 1 and 2 cylinders were misfiring. When we took outno. 2 it did look burnt, but the others looked pretty good. Believe the code wasP0300. Not sure. Could the coil pack be bad on no. 2? Also, how do you switch the ignition module? (rooky question huh). Thank you for helping me.
beamkim is offline
post #4 of 4 (permalink) Old 01-10-2011, 03:51 PM
Quoted: 86 Post(s)
P0300 is just a random misfire. You can switch the coil packs and see it for get a misfire on another cylinder. If I remember correctly, the ignition module is just held by an internal torx screw.
Mike
    1996 E320 Misfire/Shaking! SiL3nT44 W210 E-Class 14 12-29-2013 12:42 PM
    1996 e320 waterpump problems choppere320 W210 E-Class 6 04-18-2010 10:54 AM
    2000 e320 wheels fit 1996 e320? choppere320 W210 E-Class 2 10-21-2009 12:26 PM
    ABC and misfire problems cimi_s600 W220 S-Class 0 07-22-2009 06:36 PM
    1996 E320 Idle Problems 190e_merc_boy W210 E-Class 10 05-11-2009 03:21 PM
