95 E420 Acceleration and idle issues - Page 2 - Mercedes-Benz Forum
post #11 of 13 (permalink) Old 02-08-2011, 09:22 AM
Date registered: Nov 2010
Vehicle: 1994 S420L W140
Originally Posted by pepper238 View Post
That's the most help I've had so far. I'm about to replace my caps and rotors since they're pretty corroded anyway. I was hoping the harness wouldn't be an issue since just like your car the previous owner replaced the harness once already.
I am now leaning towards the ETA or pedal position sensor after reading through several more hours of threads and posts on here and other sites that i could find on anything like this. other wise it could be much deeper than I want it to be.....
bonite-S420L is offline
post #12 of 13 (permalink) Old 05-19-2011, 07:58 AM
Thumbs up problem solved hopefully
I have solved the problem in mine and I hope it helps you. My catalitic converters had collapsed completelly intenally and blocked the gas flow restricting it so bad i couldnt drive it anywhere. I had changed the 02 sensor and found that the exaust was not flowing out the rear as normal so I removed it and hollowed out the cats and refitted the exaust and perfecto, it drives like new. It solved over heating problem and fuel consumption has improved out of sight and now getting about 30 mile to the gallon. I hope this solves your problem too and that I could help.
post #13 of 13 (permalink) Old 05-19-2011, 08:10 AM Thread Starter
Date registered: Jan 2011
Vehicle: 1995 Mercedes Benz E420
Thanks for the reply, bonite, I've actually solved my problem as well! Turns out my fuel pump went bad. Fortunately I only replaced my spark plugs and Mass Air Flow sensor before spending too much.
I do however have another question. A mechanic I spoke with checked the diagnostics on the car and he found that the wiring harness for my MAF sensor is the wrong harness. The question I have is whether it's possible to have put the wrong harness on the car or could the correct harness have been improperly installed which would cause the car to give the 10 error code via the LED light (Voltage too high or low to MAF sensor).
pepper238 is offline
    300e 2.6 - hard to start, low/rough idle, acceleration issues kmcnutt77 W124 E,CE,D,TD Class 21 02-18-2014 08:25 PM
    '96 C280 Engine Issues (idle,throttle,acceleration). Help!! sideshow76 W202 C-Class 32 04-02-2013 04:46 AM
    94 E420 sometimes a little rough at idle, hesitant acceleration redheadeight W124 E,CE,D,TD Class 3 12-17-2010 01:04 PM
    What is your 97 E420 0-60 acceleration Smalls W210 E-Class 33 05-01-2010 10:53 AM
    Poor idle, sluggish acceleration ---> good idle & smooth acc ltooz W201 190-Class 30 02-18-2010 06:41 AM
