sounds of machine gun fire while door tries to lock - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 01-06-2011, 06:41 AM Thread Starter
Date registered: Jan 2011
I have a 2007 B200 turbo. We bought it last year and have had no problems with it until about a month ago. My passenger side door started making a horrible machine gun fire kind of noise when I attempted to lock it. It doesn't do this every time, but probably about 80% of the time. And then will not lock. All 3 other doors will. I thought it maybe was my remote lock battery .... except it also does this when I lock the car from the inside.
Last night I believed the car was locked, only to come out this morning to find out that apparently it wasn't, as someone had rifled through it. Just looking for change I suspect as they left the gps and all the ipod gadgets.
Anyone know what is causing this? I don't want to take it to the dealer and get dinged with a $500 service charge when all it needed was a spray of WD40!
Also, I have rust on the inside of my hatchback door. And the lining around the stick is "rough" and peeling. I've actually cut myself on this! Are these common problems with a B200?? I'm really disappointed! I drove a Kia previously and never had these problems!!
any suggestions would be most appreciated! And I know absolutely nothing about cars, so the most basic explanation would be the most helpful!!
thanks again!
annlam is offline
post #2 of 4 (permalink) Old 01-06-2011, 08:11 AM
Date registered: Feb 2005
Vehicle: '03 CL500,& '07 GL450
Thumbs up
Same thing happened on my 2007 GL450. MB tech found "that rubber boot on lock rod in door is causing lock rod to make jumping noise. Applied lube and trimmed boot. Checked functions after repairs. Central locking operates as designed."
'03 CL500,'07 GL450
reddog is offline
post #3 of 4 (permalink) Old 01-17-2012, 11:49 AM
Date registered: May 2010
Vehicle: 2006 B200, 2007 B200T
Rust is a warrantly issue. Dealer repaired mine at no cost
DKRAUS is offline
post #4 of 4 (permalink) Old 01-19-2012, 03:07 AM
Date registered: Dec 2008
Vehicle: 190e 1.8
Door lock bouncing is a common problem internal fault in the door lock, it needs a new one.
Big Unit is offline
    Replacing Front Door Lock: Actuator , Machine gun locks , etc... pleubner W163 M-Class 216 12-07-2015 06:16 PM
    machine gun lock-drivers door-intermittent ML_ W163 M-Class 3 11-11-2010 11:52 PM
    Machine gun lock - Driver door getdown03 W163 M-Class 9 12-27-2009 10:56 AM
    Machine gun door lock Infrared W163 M-Class 1 08-13-2008 05:03 PM
    Machine-Gun ratcheting noise on door lock..... ReBell W163 M-Class 0 04-30-2007 08:24 AM
