2003 S500 Running Rough at Idle - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 01-05-2011, 10:27 AM Thread Starter
Date registered: Jan 2011
Vehicle: 1999 C43 AMG, 2003 S500, 2003 C230K
Hi guys,
I have a 2003 S500 with about 60,000 miles on it, starting a few weeks ago every once in a while when I pull up to a traffic light the engine will start running rough, if i do not put it in neutral and give it a little gas it will actually stall out. It does not happen every time and does not happen that often, it could happen at one light and 2 minutes later at the next light it will be fine.
The Check Engine light did come on once and stayed on for a couple days and then went out, i always thought once it came on it would not go off until it was reset.
At speed it runs great, i have actually driven it twice from Ohio to NC since the problem started with no issues....I have run Fuel Injector cleaner through the system but can't really tell a difference.
Any ideas????
Thanks
Nick
Nabco is offline
post #2 of 6 (permalink) Old 01-05-2011, 10:40 AM
Musikmann's Avatar
Quoted: 6 Post(s)
The CEL will reset after several drive cycles if the error causing it has self adjusted. Have the DTC (diagnostic trouble codes) read with an OBD2 scanner before going any further. Autozone, etc. will do that for no charge. Good luck.
Musikmann is offline
post #3 of 6 (permalink) Old 01-05-2011, 11:04 AM Thread Starter
Thanks..can the DTC be read if the CEL has gone out?
Nabco is offline
post #4 of 6 (permalink) Old 01-05-2011, 01:44 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Yes.
When enough or certain errors are logged, the CEL is lit. If the issue is resolved, the CEL will go out on it's own (so if you drive long enough after it goes out, the codes may be erased). However, until the trigger point is hit in the algorithm, you can have stored/pending codes without ever triggering the CEL.
So get them read. Some auto parts stores will do it for free, and Aamco says they will, too. Get the codes, then check them against the list in the forum.
Also, click user cp and add your vehicle and location to your profile, it's useful information.
Good luck.
Check Codes is offline
post #5 of 6 (permalink) Old 01-06-2011, 08:15 AM Thread Starter
Thanks guys, I am going to try and get to an AutoZone today.
Profile updated too...
Nabco is offline
post #6 of 6 (permalink) Old 01-06-2011, 07:13 PM
Date registered: Dec 2008
Vehicle: w204 (C350ELE)
Post
The advise is well and good. I just will add that 60,000 miles is a big milestone for service: tranny flush, injection clean up, ignition tune up, filters replacement, probable catalytic converter failure, polution controls clean up... even though the schedule specifies some items for 100,000 miles.
It all depends on how you keep your cars, I prefer to rely upon them to start and go at any time.
A car would show appreciation for preventive maintenance by never leaving his owner stranded.
Defensive Driving is never having to say you're sorry: a true love story between man and machine.
JoeVal is offline
    I figured it out running rough problem and idle rough danberg1 W126 S,SE,SEC,SEL,SD,SDL Class 11 07-21-2010 07:20 PM
    Rough idle and running - fixed. shrimpton W126 S,SE,SEC,SEL,SD,SDL Class 11 06-17-2010 01:03 PM
    Rough idle/running rich ScottinSoCal R/C107 SL/SLC Class 46 11-07-2009 04:32 AM
    rough running s500 coupe migg48 W140 S-Class 7 03-18-2009 03:59 PM
    SLK320 rough running at idle pboland R170 SLK-Class 5 08-12-2002 05:37 PM
