A/C Cable and other questions - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 01-05-2011, 07:59 AM Thread Starter
Date registered: Aug 2010
Vehicle: 190E 8v 2.3 Mercedes Benz Make 1987
Hi Forum, I've a E190 year 1987 2.3. I just changed the A/C compressor and i might missed something. I would like to know if the A/C Compressor has 2 electric connections: the first one that starts the compressor and the electric fan and the second one to a switch or connection to the engine in order to put the idle speed of the car a little bit more up.
This question is because, my car when i'm driving with the ac off the rpm are ok, over the 1200 rpm. but when the ac is on, it drops below 1000, between 700 and 900 rpm.
The other question is related to the temperature. The car, also with the ac on marks a temp below 80 degrees. I think the thermostat is not working, but i would like to know which is the correct temp of this car in order to function perfectly.
If you need a photo of the piece that i talk about in the first question i would upload a photo just to see it.
Please help me,
Thanks in advance
rdiaz19 is offline
    questions about DIY for accelerator cable, motor mounts fredvillanueva@gmail.com W201 190-Class 1 09-06-2010 09:52 PM
    1992 400E rust repair questions, and general restoration questions Zack1978 W124 E,CE,D,TD Class 6 10-04-2008 07:02 PM
    how to adjust throttle cable or the accelerator cable 300te 1992 autosleek W124 E,CE,D,TD Class 0 07-21-2008 10:01 PM
    More C230 Questions.. This Owners manual makes no sense...Lighting questions..HELP.. Blackvette W203 C-Class 3 02-19-2008 05:17 AM
    Battery cable questions Loi R170 SLK-Class 3 05-18-2006 06:17 PM
