New secondary air pump burned up - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-04-2011, 07:01 PM Thread Starter
Date registered: Dec 2010
Question New secondary air pump burned up
Recently replaced the secondary air pump on 1999 ML320. The old one was burned up so thought this will be an easy repair. Installed the new pump, cleared the fault code, closed the hood. Four days later the check engine light came back on. Checked the codes and sure enough "secondary air fault". Checked the fuse and yep its blown. Test the air pump motor and it was burned up. Soooo, what would cause the two pumps to burn? If the valves were not opening or the ports in the head were clogged it would seem that the fan would dead head but as it is only supposed to operate on cold start it does not seem that should overheat it to failure. Any insight will be greatly appreciated.
Dahunter is offline
post #2 of 3 (permalink) Old 01-05-2011, 02:34 AM
Date registered: Jan 2007
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
have you checked the relay??? if the relay is sticking then it will cause the pump to run all the time thus overloading the pump and blowing the fuse
Streetglower is offline
post #3 of 3 (permalink) Old 01-08-2011, 08:05 AM Thread Starter
Finally got a chance to test the relay function. It cycled on and then off at the 90 second interval as it is supposed to (my understanding anyway). Obviously, it could be sticking at some time and I will replace before trying another air pump. Both of the failed air pumps got so hot they melted the brushes out of the plastic motor housing. Voltage is okay at 14 volts. Am I missing something else????
Dahunter is offline
    I need help with my ML430 Air Pump Burned! KAYLASML W163 M-Class 15 03-19-2010 07:07 AM
    WHAT IS THE FUNTIONS : SECONDARY AIR PUMP SilverW220 W220 S-Class 1 06-17-2008 11:13 AM
    Servicing a Secondary Air Pump pcy W163 M-Class 1 03-30-2008 04:42 AM
    Secondary Air Pump Jeff522 W210 E-Class 0 10-14-2007 09:00 AM
    Secondary Air Pump laxman0324 W163 M-Class 3 02-26-2006 06:12 PM
