Sprinter 311 CDI brake problems - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-03-2011, 06:56 AM Thread Starter
Date registered: Jan 2011
Vehicle: 2006 311 CDI sprinter converted to campervan
Angry Sprinter 311 CDI brake problems
This is my first post so forgive me if this has been answered elsewhere. Recently went to move my 2006 sprinter camper van after it had been parked up for just over one month. Brakes felt normal until i started the engine then the pedal slowly sinks all the way to the floor when pressure applied. You can pump it and get normal brake feel and brake work OK but then pedal goes back to the floor. i have checked thoroughly for leaks at all wheels and everywhere else no fluid leaking and level in res is good. Stripped down the master cylinder all looked good. Would buy a replacement but it has the upgraded master cylinder with larger bore 25 not the normal 23 and no one seems to have one. I would buy the new master cylinder but i would like to be sure b4 i spent £200+. (no job at the moment) I have had several suggestions that it could also be ABS pump??. I have completely changed the fluid and used pressure unit to bleed the brakes. sorry for the epic but thought it might save time. cheers
poolshark is offline
post #2 of 3 (permalink) Old 01-03-2011, 06:09 PM
Date registered: Dec 2010
Vehicle: 1995 SL500; 2009 Vito Comfort
Hello,
I can only think of a leak somewhere in the system. Have you checked all calipers, distribution couplers and fasteners?
Also, if you have changed the fluid, there are some ABS systems which have to be bled separately and with the help of the diagnostics tool in order to activate all actuators and remove any air internally.
Good hunting to you and cheers from Mexico!!
dannymex is offline
post #3 of 3 (permalink) Old 01-03-2011, 09:35 PM
eric242340's Avatar
Quoted: 295 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car. At the bottom of the page you will find forum jump, click on this and view all the available sub forums.
Regards
Eric
ERIC.
eric242340 is offline
    Mercedes Sprinter 311 CDI - Not Starting k3nty W901-905 Sprinter 11 03-31-2012 04:10 PM
    sprinter 311 cdi cutting out mikeyc180 W901-905 Sprinter 12 01-15-2011 05:53 AM
    Major service on 2001 311 CDi Sprinter chodecz W901-905 Sprinter 1 11-08-2010 07:27 PM
    SPRINTER 311 CDI BATTERY DISCHARGE MERCURY3CYL General Mercedes-Benz 0 02-07-2009 09:49 AM
    sprinter 311 cdi Chewy2k3 W901-905 Sprinter 0 04-18-2007 05:24 AM
