s 500 power window problem - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 01-01-2011, 05:19 AM Thread Starter
Date registered: Feb 2008
Post s 500 power window problem
My drivers side window on my 1998 s500 will not stop running once it is fully up. When I raise the window it goes all the way up and if I keep my finger on the button it will continue to run. Is this a switch problem or something else.
eroyko is offline
post #2 of 4 (permalink) Old 01-01-2011, 10:03 AM
jfamondone's Avatar
Date registered: Mar 2006
Vehicle: 2007 ML 350 Iridium Silver/ Ash (Sold)
Hello eroyko,
Please post your question on the W140 forum. I'm sure you will get your problem answered very fast.
2007 ML350, Iridium Silver/ Ash MB Tex
1996 S320LWB, Brilliant Silver Metallic / Gray Leather (SOLD)
2004 S500, Black / Charcoal Leather (SOLD)
2006 C230 Sport, Granite Grey / Black MB-Tex / Leather (SOLD)
2003 E320, Brilliant Silver Metallic / Charcoal Leather (SOLD)
2002 ML320, Everest Green Metallic / Java Leather (SOLD)
jfamondone is offline
post #3 of 4 (permalink) Old 01-01-2011, 04:51 PM
Date registered: Jan 2007
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
take your finger off of the button whats its up
Streetglower is offline
post #4 of 4 (permalink) Old 01-02-2011, 06:27 PM
Date registered: Nov 2010
Vehicle: 1994 S420
You say it keeps going, is it possible the motor "teeth" are slipping inside the regulator and sounds like it is still turning. When the window reaches the top, about all you should hear is a motor hum, not a motor running.
Otherwise, there are two switch positions...first position is manual up, second position is auto up to fully closed.
..if you will depress and hold the switch fully in for two seconds extra when it reaches the top, the unit is supposed to auto program the position and stop their automatically next time.
So, starting from the window open position, fully push the button to raise the window, and hold for at least two more seconds when it reaches the fully closed position.
If that doesn't work then there could be something going on with the window motor which the controls are not sensing the motor status. Once the window is blocked, the motor locks and the amps/resistance around the motor coils should change which is how it knows to shut itself off. German engineering.
Three Year Owner - Green 94 S420 w/90k
Nissan Solar Yellow Xterra 01 w/188k
ramblinche81 is offline
    Power window problem - help jmcdowell W201 190-Class 3 05-04-2010 11:33 PM
    sl 500 window problem xxxxxxxschabey R129 SL-Class 16 05-12-2007 08:49 AM
    Power window problem 79Mercy W123 E,CE,D,CD,TD,TE Class 6 05-08-2007 11:57 PM
    S 500 2000 window problem and more Remax Audio & Telematics Forum 0 09-21-2005 08:22 AM
    Power window problem...help! Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 8 10-23-2003 07:39 PM
