2000 MLK 320 chevy small black engine swap - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-28-2010, 01:37 PM Thread Starter
Date registered: Dec 2010
Hello Benzworld! This is my first post so i hope it goes swimmingly....
If you read the topic and said, what the H?, I do not blame you. I have a 2000 ML 320 sitting in my garage that I would like to get up and running again. The last diagnosis given on the vehicle was that it was miss firing on 4 cylinders. Since then my mom has gotten a new car and it has been sitting for about 3-4 years...besides the engine, there are some other things wrong but very fixable(alignment, new tires, etc.) Currently, it does not run and in order for it to be really looked at the thing would need to be flat bedded to my mechanic. Coils were replaced along with spark plugs so what the problem is I could not say... some ideas were simply the fuel pump or the engine is just done. In four years there was 200,000 miles put on engine. So being the person I am, creativity set in and I've been pondering the idea of dropping a chevy 350 small block into the German machine. My brother, being a mechanic, gave me about a million reasons why it's not a very good idea. I just want to know if anyone can give me a firm answer as to the possibility of the idea. Yes it will need to be rewired, some new motor mounts, what ha. But, is there anything else that would need to be done?
99passatB5 is offline
post #2 of 3 (permalink) Old 12-28-2010, 02:51 PM
Kajtek1's Avatar
Quoted: 1068 Post(s)
The main problem on those cars is computerized system. Even if the Chevy engine doesn't have the computer, how it will talk with the transmission?
There is one member who put Toyota Supra engine in E class, but it was project of love and took way longer than anticipated.
200k for 320 engine is not that much. Did you do compression test? Might be that the only problem is bad MAF?
What I am getting to is, that if you can restore well design MB engine, why would you put clumsy Chevy in it?
Welcome to the forum.
Kajtek1 is offline
post #3 of 3 (permalink) Old 12-28-2010, 04:14 PM Thread Starter
Thanks for the welcoming and no I do not think it has had a compression tested. I hate seeing it in the garage so I've been contemplating putting my VW up for sale to fix it. 5k would be the min I would be looking for out of the sale so that's what the budget would consist of; Probably way less of whats needed to feasibly do the swap. I will look further into fixing her with what she has.... Thank you for your help. If anyone can provide any suggestions that would be great!
    swap 320 engine into 230? slk_jason R170 SLK-Class 30 02-23-2015 10:58 AM
    1990 300ce engiune swap with a JDM engine or small block chevy 32FLOZ General Mercedes-Benz 23 02-21-2013 07:21 PM
    W460 Engine swap info? Chevy!? aussiG G-Class 14 08-16-2011 04:56 PM
    CHEVY ENGINE SWAP??? CCWHEEL W201 190-Class 14 06-24-2010 10:14 AM
    2000 CLK 320 engine problem chavez_j C208/A208 CLK-Class 5 03-07-2010 07:40 PM
