Rim question for 300td - Page 2 - Mercedes-Benz Forum
post #11 of 12 (permalink) Old 12-28-2010, 01:31 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Originally Posted by redpiper View Post
Okay, I'll be on the lookout for a set of 14" bundts. Car is actually a 300SD turbo, though I don't think that changes anything.
Thanks.
Actually it does.
The 300SD is a W126 and W126 use wider wheels and larger tires than W123.
You'll want the proper wheels for a W126.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #12 of 12 (permalink) Old 12-28-2010, 03:30 PM
Date registered: Dec 2009
I have some updated info., though I don't expect it will change anything. The rims are actually 16". The leaking one is due to the hole for the stem not being quite round. I had a better rubber fitting put in today and did put a bit of silicon on it. It seems to be holding for now, but we'll see..........
I"m sure it will be fine - just drive it, make sure you have a decent spare and wheel change gear, and stop worrying. if it goes again, maybe then get back to the worrying, which still be there waiting for you if you need it.
gmonkey is offline
    Rim question mikez W204 C-Class 3 03-28-2010 04:22 PM
    HELP!!! Rim question Snakeeyes03 W203 C-Class 9 10-27-2009 10:08 AM
    Rim Question Dieffenbach W204 C-Class 0 05-20-2009 08:02 AM
    rim question... lonelyboi909 W210 E-Class 6 06-13-2007 12:07 PM
    Luke, Rim options for '81 300td? Wagon dreamer The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 06-05-2006 07:15 AM
