2002 E320 4Matic - Transmission Gremlin? - Page 2 - Mercedes-Benz Forum
post #11 of 14 (permalink) Old 01-06-2011, 05:39 PM
ingydrummer's Avatar
Date registered: Jan 2010
Vehicle: 2005 E-500 4Matic Sedan Brilliant Siver
[This happened on my 03 320 4matic, and they told me it was a shift plate in the trans. It wound up costing me $1250.00 plus labor.
ingydrummer is offline
post #12 of 14 (permalink) Old 06-13-2011, 10:29 PM
Date registered: May 2011
Vehicle: 2001 Mercedes SLK320; 2002 Mercedes E320 4Matic S/W; 1990 Mercedes 420SEL
Mine has gone into the limp mode, and when I opened the pan, and found there was actually coolant in the fluid. Took out the Valve Body, and now will be testing the Solenoids, and will have to replace the Electric Conducting Plate (Electrics Plate), and flush the transmission of all and any remaining coolant. Refill, and test. Might have to go see the Benz Dealer for programming. Anyone has any other thoughts?
navreet is offline
post #13 of 14 (permalink) Old 06-14-2011, 02:41 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 373 Post(s)
Do you have a Valeo radiator? If so, look up the threads on the leaking Valeo problem in the archives...
keyhole is online now
post #14 of 14 (permalink) Old 06-14-2011, 02:51 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Whatever radiator he has, he needs a new one.
Navreet, flush the cooling lines before you reconnect them and actually leave the supply line loose from the radiator. When you start it back up let it flush out 1L and refill 1L at a time until you've done that about 9 times to be sure you get it out of the torque converter.
I'd probably do another fluid change in a few thousand miles.
Good luck.
Check Codes is offline
    2001 E430 4matic or 2002 E320 4matic alexnatt W210 E-Class 16 08-02-2010 11:54 PM
    New to me 2002 E320 4matic AWD Sibarks General Mercedes-Benz 2 12-05-2009 07:06 PM
    OBDII for my E320 2002 4matic wagon, where should I get one? Maflaya W210 E-Class 2 08-15-2008 06:14 PM
    Is this nice or what!? 2002 E320 4matic on ebay. ozcan W210 E-Class 12 07-24-2008 09:57 PM
    RIMS FOR 2002 E320 4MATIC Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 11-16-2001 06:38 AM
