Airbags deployed vehicle engine disabled after crash..... - Page 2 - Mercedes-Benz Forum
post #11 of 46 (permalink) Old 12-22-2010, 11:40 AM Thread Starter
J4GG4's Avatar
Date registered: Nov 2007
Ok so ive had a star machine hooked up and i get these faults:
AB AIRBAG -F
DR SIDE SAM DRIVER SIGNAL Acquisution and actuaton module -f
REAR SAM rear signal acquisition -f
OCP overhead control panel -f
UCP upper control panel -f
LCP lower control panel -f
IC instrument cluster -f
ASSYST active service system -f
SCM MRM steering column module -f
PTS parktronic system -f
AQW audio 20 with integrated gateway -f
DCM FL door control module -f
DCM FR door control module -f
So obviously the major fault is the airbag module, My question now is it obviously needs re coding(or replacing?), can me and my friend do this ourself with the star machine? if yes what are the steps to take to do this? If one would be kind enough to guide. Would like to understand this software better.
Also any other thoughts on the above much appriciated.
J4GG4 is offline
post #12 of 46 (permalink) Old 12-22-2010, 12:43 PM
Diesel Benz's Avatar
Quoted: 39 Post(s)
AB AIRBAG -F
Didn't you get any of the codes read, just the quick test result? SRS control unit would have been interesting, others not that important as you say.
Diesel Benz is offline
post #13 of 46 (permalink) Old 12-22-2010, 01:34 PM Thread Starter
J4GG4's Avatar
You mean the exact faults with the srs module? if so i can hook it up tomorrow and tell you exactly whats failing..
J4GG4 is offline
post #14 of 46 (permalink) Old 12-22-2010, 02:01 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 395 Post(s)
When you replaced the airbags (how many had operated?) did you also replace the associated ignition squib which would have fired the airbag?
There are many (R12/1 - R12/17) that are all routed into the Restraint System Control Module (N2/7)
keyhole is offline
post #15 of 46 (permalink) Old 12-22-2010, 05:06 PM Thread Starter
J4GG4's Avatar
The passenger seat and passenger roof airbags deployed, there the only ones i replaced. I'll put a full list of faults up from the srs im pretty sure there was a fault for every airbag inc driver seat airbag, steering wheel airbag..ect even though they wasnt deployed
J4GG4 is offline
post #16 of 46 (permalink) Old 12-24-2010, 04:38 PM Thread Starter
J4GG4's Avatar
Ok guys, star hooked up again.. Opened up AIRBAG faults and here is what i have...
So Before the test i replaced the passenger airbag AND the roof curtain airbag. It mentions no other faults with AB system apart from coding is faulty, as mentioned would happen from a member on this thread. So can i code myself using the initial startup feature? If yes what should i expect it to ask me/what will it do..ect? Im guessing i cannot.. but in which case, could i use original srs module or should i purchase a brand new one?
By the way last time i used star i erased the faults but there back again.(ie.. pass airbags resistance too low/high) why did they come back if i replaced the airbags?.
J4GG4 is offline
post #17 of 46 (permalink) Old 12-24-2010, 11:27 PM
Quoted: 39 Post(s)
Did you switch ignition on while you were working with the car and one of the airbags disconnected?
There could be a trick that you could try but you should get rid of the fault codes first. There must be a current issue with the front passenger airbag. The airbag connectors are typically such that the aribag side gets short-circuited when the connector is unplugged (either from the control unit or from the airbag itself). Perhaps one of the connectors is not installed properly to release the protective short-circuit (the short-circuit is intended to disable the airbag from firing up from static electricity discharges etc.).
post #18 of 46 (permalink) Old 12-29-2010, 01:44 PM Thread Starter
J4GG4's Avatar
Sorry been a while our star software corrupted, but we have it all sorted again. Fresh install from dvd.
Anyway i reseated the passenger seat airbag connector and ran a retest and it found the fault again. I cleared faults and ive ran a quick test 3 times and it hasnt picked the faults back up, even the airbag control unit coding faulty fault didnt pick up..(not sure if you have to wait a certain time before retesting?) Also when i did click initial coding it says the airbag control module is already interlocked and parameterization is not possible. Does this mean its unlockable? and i need a new airbag control unit?
But anyway i have one more major fault (-F) and it is short circuit on all glow plugs. It says check the resistance for each plug.. but im guessing the CDI control unit has the fault and not the plugs?
J4GG4 is offline
post #19 of 46 (permalink) Old 12-30-2010, 04:25 AM
Quoted: 39 Post(s)
So you mean you got rid of all fault codes, even the control unit coding? There is a means to unlock the control unit via special functions but I doubt it would help here because of the crash data that would have to be cleared with other means.
post #20 of 46 (permalink) Old 01-01-2011, 04:48 AM
keyhole's Avatar
Quoted: 395 Post(s)
Additional information
I don't have precise data for your W219, but here is the WIS page on the function of the Restraint System control unit (N2/7) for a W211, which you may find useful. This is located beneath the tunnel.
Additionally, I have read that there are 2 Frontal Acceleration sensors located on the radiator cross member. B48/1 (US drivers side), and B48/2 (US pass side). These should be replaced after a head-on collision, if the mounting area metal is deformed.
keyhole is offline
    when roof curtain airbags are deployed........ J4GG4 General Mercedes-Benz 4 12-12-2010 05:17 AM
    both front airbags were deployed mbzneedshelp General Mercedes-Benz 1 02-11-2010 04:52 PM
    S Class Airbags Fail to Deploy In Chinese Crash Ryanoscerous MB Safety & Testimonials 29 01-26-2008 12:57 AM
    Disabled vehicle adaptation, finally Samoila Stefan W201 190-Class 17 02-17-2007 08:38 AM
    OT: 2 driver side airbags deployed on heavy braking.... adrose R170 SLK-Class 6 10-11-2004 07:40 PM
