1990 500SL Fuel Issue SOMEBODY Help Please!? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-15-2010, 09:47 PM Thread Starter
Date registered: Jan 2009
Vehicle: 1970 280SEL, 1986 420SEL, 2002 C280
Post 1990 500SL Fuel Issue SOMEBODY Help Please!?
Nobody has ever responded to any of my questions so I figured Id try again. I have a 1990 500SL. It had a rough idle and a misfire on one cyl. I did the brake parts cleaner test around the intake and found that there was a intake leak around the 2nd cyl up from the drivers side (I am assuming that is cyl #7) So I replaced the intake manifold gasket and all of the little hoses associated with that job, I put it all back together and I still have a slight air leak on that cyl (a small vacuum leak isnt my biggest concern right now). I also figured id try swapping my regulator with my 420SEL... still no difference. However if I loosen one cyl at a time from the top of the fuel dist they all puddle up at the top of the hose EXCEPT that one. I am not familiar with the inner workings of a fuel distributor however I was considering buying a rebuilt one and read in the manual that cyl #7 may go out due to low fuel pressure (is that even cyl #7), has anybody ever heard of that? I dunno what direction to go, what is the proper pressure and where is the best place to take a reading? Before or after the regulator? In addition, if I richen the mixture on the tower that cyl starts working and I can get a puddle but its WAY too rich and I start getting dizzy... so I dunno replace fuel pumps? Replace fuel distributor? What am I looking for? Could there possibly be more?
I would appreciate ANY response.
Also Replaced:
-Oxygen Sensor
-Idle Control Valve
-Caps, Rotors, Plugs & Wires
-Injectors, Cups, Seals, Hoses
-Fuel Filter
-Springs, Shocks & Struts
-Power Steering Pump
-Fan Belt
-Misc Bushings
alexsystems is offline
post #2 of 3 (permalink) Old 12-16-2010, 02:04 AM
Chicky's Avatar
Date registered: Apr 2007
Vehicle: 1991 R129 500SL
Quoted: 57 Post(s)
Hello alexsystems,
If you scroll down further the discussion forums, you'll see the MB Roadster forums, R129 subforum, try posting the question there.
Chicky
Chicky is offline
post #3 of 3 (permalink) Old 12-17-2010, 04:12 AM
NEOKEN's Avatar
Date registered: Dec 2007
Vehicle: 95 SL500, K&N, NEOKEN Ported TB, Custom Intake, RENNtech Sport Exhaust, AMG I Monoblocks
Quoted: 30 Post(s)
Agreed, you will probably receive a better response within the confines of the R129 community.
NEOKEN is offline
    1990 500SL: fuel gauge sender or something else? Stirling500 R129 SL-Class 6 06-23-2011 05:31 PM
    500SL Misfire Issue! Bad Fuel Distributor? Low Pressure? alexsystems General Mercedes-Benz 0 08-28-2010 11:12 PM
    FS: 1990 500SL Cruzrmm55 For Sale/Wanted/Trade/Giveaway 0 04-23-2008 07:08 PM
    1990 500SL britincanada For Sale/Wanted/Trade/Giveaway 0 12-19-2007 03:43 PM
    original tool kit for 1990 500sl & how many 1990 500sl's produced philips General Mercedes-Benz 0 06-06-2004 07:49 PM
