1989 MB 300E starts when cold but dies when hot - Page 2 - Mercedes-Benz Forum
post #11 of 11 (permalink) Old 01-31-2012, 04:07 PM
Date registered: Jan 2012
Vehicle: 92 400se, 01 ml320, 83 280SL, 79 6.9, 72 300sel 3.5, et al
try this when it fails, replace the fuel pump relay, `behind the battery, its the one NOT mark KLIMA., if you dont have a spare, pull out the relay and look at the pins and locate the ones numbered 87(fuel pump) and 15 (ignition) or 30(bat). locate the corresponding holes in the receptacle and connect the 87 and 15 and see if the engine starts. if so the relay has a clod soldeer and you can open it and resolder. it will be pretty obvious if yopu know what good slder connection looks like. pls post your result.
Seize the Day
cronix1 is offline
    87 300e starts hard & dies when throttle applied woody-500 W124 E,CE,D,TD Class 3 03-05-2010 01:57 PM
    90 300e Very cold starts, what to expect? Growl W124 E,CE,D,TD Class 4 09-18-2008 08:03 PM
    560 SEC hard starts hot or cold, idles high swtexmbnut W126 S,SE,SEC,SEL,SD,SDL Class 3 08-01-2008 08:08 PM
    '88 300E will not idle - starts then dies, idles fine when ICV is unplugged- help! GermanCarNut W124 E,CE,D,TD Class 1 12-30-2006 10:08 PM
    87 mers 190E 2.3L HELP CAR DIES OUT starts on Cold NightOfDarkness W201 190-Class 3 10-25-2006 02:01 PM
