Vacuum valve - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 12-13-2010, 10:39 AM Thread Starter
Date registered: Oct 2006
Vehicle: 1991 420 SEL
Question Vacuum valve
1991 420SEL. While replacing vacuum valve/check valve the one located on the false fiire wall MB P/N 126 800 00 78 (yellow and gray) the little tit on the inlet side fed from the intake broke off. And, the starred "nut" that holds it in place desintegrated during removal. I ordered a replacement only to find it doesn't come with the "nut". I just assumed it came as a unit. I checked every site that sells parts and none of the pic's show it with or, as a separate part. Calls to the vendors and they don't even know what I talking about.
Does anyone know where to get a hold of the "nut" for this valve or,the P/N?
the P/N?
TIA, Dave
DAVECAD2.0 is offline
    Vacuum Valve 3/2 Way WANTAMB W123 E,CE,D,CD,TD,TE Class 11 09-25-2013 02:13 PM
    vacuum pump OR check valve? low vacuum... type2meister W123 E,CE,D,CD,TD,TE Class 16 05-19-2009 07:53 PM
    vacuum modulator valve desfam5 General Mercedes-Benz 1 04-28-2009 08:36 PM
    vacuum check valve Beverly Sharp W116 S, SE, SEL, SD Class 1 11-18-2008 07:43 PM
    Vacuum Valve dxj_1 W124 E,CE,D,TD Class 1 10-16-2006 03:59 PM
