300SE Overheating issue? HELP!! - Page 2 - Mercedes-Benz Forum
post #11 of 13 (permalink) Old 12-19-2010, 11:11 AM Thread Starter
Date registered: Dec 2010
Thanks much for help! Problem likely was mostly due to too much sludge built up in system from the oil mixing with coolent engine design flaw and not having done a good flush in quite a while. And fan clutch is weak so think problem was probably a number of things all adding up to problem. Can't be sure if it was water pump or thermostat, replaced both, did best flush I could, all seems normal now.
drwexploring is offline
post #12 of 13 (permalink) Old 12-20-2010, 06:18 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 81 Post(s)
I would remove and inspect the back of the fan clutch. It can break sort of in a ring shape. If it does, the fan will wobble and come loose. I found this out the hard way last summer. "Luckily" the fan hit the radiator instead of damaging anything else. Here is a thread about it:
http://www.benzworld.org/forums/w126...-pump-but.html
Mike
Michael Pillay is offline
post #13 of 13 (permalink) Old 12-20-2010, 08:54 AM Thread Starter
hey Thank you for the heads-up!!! APPRECIATE IT!!! Will have a close look at that.
HAPPY HOLIDAYS!
    All things considered (300se overheating issue) Htown W126 S,SE,SEC,SEL,SD,SDL Class 32 06-08-2014 03:24 PM
    Overheating Issue yoffer W210 E-Class 4 06-24-2010 04:34 PM
    300SE Overheating Problemo hvc78 W140 S-Class 6 03-04-2010 05:46 AM
    overheating issue. jbrunner27 W126 S,SE,SEC,SEL,SD,SDL Class 2 09-16-2007 03:00 AM
    Overheating Issue satyr W201 190-Class 6 05-18-2005 02:03 PM
