Question on '85 300D Alignment - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 12-08-2010, 08:14 AM Thread Starter
Date registered: Oct 2006
Greetings. I have an '85 300D with 149k miles. I am experiencing excessive tire wear on the outside of the left front tire. Assuming that I need an alignment. There seems to be a mixed bag of "yes, no, maybe" from independent shops on whether they can do an alignment on this vehicle. The dealership indicates they can do a 4-wheel alignment on this vehicle. I am wondering if a)can 4-wheels be aligned and b)has anyone had any success with independent shops doing this work?
Thanks in advance and Merry Christmas.
turboJOB is offline
post #2 of 4 (permalink) Old 12-08-2010, 11:41 AM
DirectLA's Avatar
Date registered: Jan 2007
Quoted: 8 Post(s)
In my experience the dealer isn't much more expensive, if any, than other indie shops for aligning these cars. My c230 had a 4-wheel alignment done for $125 at the dealer and it would have been $100 at an indie. The dealer will also have the proper specs, which an indie should also but you never know, and finally you want to be sure that whoever does the work uses a spreader bar to simulate the weight of the vehicle in order to gain the proper adjustment.
The Coupe Group on Facebook
DirectLA is offline
post #3 of 4 (permalink) Old 12-08-2010, 12:27 PM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T current 2014 lexus LS460
Have the dealer do it, the first step is to center the wheel, and then the spreader bar. Many shops attach their equipment and adjust only one tie rod.
Peter Guenther is offline
post #4 of 4 (permalink) Old 12-08-2010, 03:27 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Have the dealer do it because you probably have broken/bent/worn suspension parts and the independents won't have them. Cars don't "go out of alignment" unless something like that has occurred.
Kent Christensen
'07 GL320CDI
lkchris is offline
    Alignment question..... Eyesofdark80 W124 E,CE,D,TD Class 9 07-01-2010 09:20 AM
    alignment question vr6freak The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 09-01-2007 07:13 AM
    alignment question vr6freak W124 E,CE,D,TD Class 2 08-26-2007 08:02 AM
    '81 300D - Pulley alignment Belvario W123 E,CE,D,CD,TD,TE Class 8 12-07-2003 05:16 PM
    Need HELP with alignment parameters question: getting alignment redone tomorrow. Dan - SF Bay Area R170 SLK-Class 13 01-10-2002 10:34 AM
