'84 300SD Bad Head Gasket?? (w/Pics) - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 11-28-2010, 12:47 PM Thread Starter
Date registered: Dec 2009
Question '84 300SD Bad Head Gasket?? (w/Pics)
I have a 1984 300SD with 220k miles on it. It has the "shaking at a stoplight after a long highway run, with almost no power afterwards" problem. Tried the rack damper bolt, fuel filter, and adjusted the valves with no effect, and it slowly got worse, to the point where you would stop at the light and the engine would go THUD THUD THUD a few times and die.
Did a dry, cold compression check and came up with these numbers:
340, 360, 340, 300, 250
Decided to remove the cylinder head. Nothing visibly wrong with the head, or block. No cracks in the head gasket, but it is well worn, and looks most worn on #4 and #5, matching up with the compression check. I will attach pics of the whole gasket, and a closeup of the front and back of #4 and #5. Is this damage enough to cause these compression numbers?
bistromath is offline
    bad head gasket ... 300SE 1990 !!! Jabpir8 W126 S,SE,SEC,SEL,SD,SDL Class 6 11-27-2007 11:48 AM
    1996 E320 head gasket bad, please help AMG55E W210 E-Class 6 12-04-2006 01:58 PM
    1992 300e 4m bad head gasket.. neidermeyer W124 E,CE,D,TD Class 2 10-08-2006 10:22 AM
    Bad News !! Head gasket!! StarGazer W201 190-Class 10 09-11-2006 07:22 PM
    Bad news from my mechanic - Head gasket replacement AxelWulff W126 S,SE,SEC,SEL,SD,SDL Class 22 03-28-2005 12:19 PM
