722.6 Transmisison - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 11-25-2010, 06:26 AM Thread Starter
Date registered: Sep 2010
Post 722.6 Transmisison
Hello, this is my first time on the forum, but I have used this site quite alot, THANK YOU THANK YOU THANK YOU.
But now I am quite stumped:
I drive a 1999 W202 C240 SPORT Auto. (722.6 tranny)
I have a whine on overrun in 1st and 2nd gear, also a slack some where in the drive train in these gears, provoked by light throttle or letting it cost to a stop on down shift.
Things done so far:
New Engine and Tranny mounts
New Prop Shaft
New Central Bearing
New Flex Disc\Prop Couplings (front and back)
New Diff Oil
Drained 5L of ATF new FIlter and MB ATF Fluid to correct level
New Electrical plug on the tranny (known issue), no oil in the ECU but is on the loom)
any help would be greatly apprecieated, I have no codes stored, scanned numerous times, I was thinking could it be a loose flange nut on the gearbox output shaft that could cause the slack and the whine ?
Mems is offline
post #2 of 2 (permalink) Old 11-28-2010, 10:43 PM
eric242340's Avatar
Quoted: 283 Post(s)
The link below is the stikies for the E class forum and this vehicle uses the same transmission as yours, so read through this and welcome to Benzworld;
eric242340 is online now
    DIY Mercedes 722.3 722.4 722.5 Transmission K1 Piston Spring Repair Kit Install HATTENATOR W201 190-Class 83 10-27-2010 11:19 AM
    2001 S500 Transmisison Fluid tabocat W220 S-Class 1 09-29-2010 08:06 AM
    Transmisison bushing replacement sokoloff W210 E-Class 0 08-06-2010 09:13 AM
    Transmisison service samjesse W203 C-Class 0 07-21-2010 03:01 PM
    Dealership Redemption on Transmisison Valve Body 4themasses W251 R-Class 6 12-11-2009 05:37 AM
