2002 Mercedes C240 crazy electrical problem - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 11-16-2010, 05:22 AM Thread Starter
Date registered: Oct 2010
My 2002 C240 will start cycling through faults on the display. It says faulty display SOS, SRS, some Electric bolt looking thing sometimes bad battery and a few others. It also turns the high beam blue light on and other random lights on the display. It has even turned on my windshield wipers and honked my horn. Then it will stick on SRS. I have replaced the instrument cluster, Unhooked the telleaide, replaced the steering control module. Every time I have reset the codes and then drove the car. usually the next morning but a couple of times it has taken days, but then it will start cycling the codes and finally stick on SRS. My next step is the Front Sam, and then maybe the SRS module. Any one ever encounter this?
drjrb007 is offline
post #2 of 3 (permalink) Old 11-16-2010, 04:29 PM
Date registered: Dec 2008
Vehicle: w204 (C350ELE)
Everything you detail recommend a computer diagnostics check, followed with the correcting resulting codes and pertinent action. Updated/upgraded software should be easy to find by the dealer, and cost for this should be zero.
Then is time of checking the system work, and fix it if/as needed.
A car would show appreciation for preventive maintenance by never leaving his owner stranded.
Defensive Driving is never having to say you're sorry: a true love story between man and machine.
JoeVal is offline
post #3 of 3 (permalink) Old 11-17-2010, 03:05 AM
Date registered: Jan 2007
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
your stupid for just throwing in parts till it stops. go to the dealer and have it diagnosed.
Streetglower is offline
    Electrical problem CL500 2002 cl500benz C215 CL-Class 9 01-01-2014 11:38 AM
    2002 Mercedes C240 BurtReynolds W203 C-Class 6 01-10-2010 12:59 AM
    Help! Crazy Electrical Problem! marshamk W124 E,CE,D,TD Class 1 02-10-2008 05:15 AM
    Crazy antitheft alarm, 2002 C240 Guest (MBNZ) W203 C-Class 3 02-07-2008 09:09 AM
    Crazy antitheft alarm, 2002 C240 Guest (MBNZ) Audio & Telematics Forum 3 03-10-2002 06:18 AM
