07' GL450 rpm doesnt go over 4k - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 11-13-2010, 04:29 PM Thread Starter
Date registered: Nov 2010
Question 07' GL450 rpm doesnt go over 4k
Hi guys!!
I drive my GL450 at 55000mi.
3-4 days ago 'engine check' was seen... and then 'esp malfunction' signal turned on... and the lights turned off.
today... My gl doesn't wake up if I crank less than 4 sec. And the max rpm is less than 4100rpm. There's shaking & vibration at peak idle.
what should I do??? Have you ever seen this?
Marid is offline
post #2 of 3 (permalink) Old 07-11-2012, 12:29 AM
Llandaff's Avatar
Date registered: Jul 2012
Hi,
I have same problem with my 2006 GL450 (km 150000 mileage). First it was vibrating, vibration was so strong, that I felt shaking all over the saloon. I've opened the bonnet, engine was shaking inside.
Now it doesn't even start, it is trying for couple of seconds i hear cracking noise, but no luck, car became immovable.
What that could be, if anyone knows?
Thanks!
Llandaff is offline
post #3 of 3 (permalink) Old 07-16-2012, 11:22 PM
Llandaff's Avatar
Mechanics tried to replace spark plugs, Air flow sensor and cleaned up the throttle. Problem still exists.
Last one left is to replace injector nozzles, which is costly, but hope it will help
I'll report on issue as soon as I'll get car from workshop.
Llandaff is offline
1973 450sl coil doesnt spark and doesnt have power ghumberson@knew-line.com R/C107 SL/SLC Class 22 05-08-2012 11:46 AM
07' ML 350 ML4EVER888 General Mercedes-Benz 0 09-19-2010 05:24 PM
07' GL450 raimac_56 General Mercedes-Benz 1 06-26-2010 01:52 PM
My 07' White/Ash GL450 Debut...Enjoy.. T Class X164 GL-Class 5 02-27-2007 11:44 AM
07' G Series 500 G-Class 4 08-02-2004 05:47 PM
