B Service Invoice - Page 2 - Mercedes-Benz Forum
post #11 of 20 (permalink) Old 11-13-2010, 08:54 AM
Musikmann's Avatar
Quoted: 6 Post(s)
Sorry too, our discussion of the German word is off-topic although somewhat interesting.
Except for the $9 ($4 Fuel Injector Cleaner, $3 Windshield W, $2 Seal Ring) then we are down to the $116 brake service. I would guess the $99 was the labor and $17 for the fluid.
keyhole said that is not mandatory and I believe him. MB does suggest/recommend that and I had it done because the tech thought it was a good idea too. It's been about 2 years since mine and I think I'll pass if they want to do it again. We should be able to keep an eye on it ourselves. IIRC, the reservoir is not hard to find.
Musikmann is offline
post #12 of 20 (permalink) Old 11-13-2010, 09:14 AM
Vehicle: Several MB's
Originally Posted by 10001 View Post
I just recently went to get the B service for my slk. My service rep wasn't much help, so hopefully someone here can shed some light.
When I went in to get the A service at a different MB dealership they just charged me for the service which was about $200
For service B they charged me
$250 for service which I was expecting
$36 for Mobil 1
$18 for TS Filter
$3 Windshield W
$2 Seal Ring
If the service doesn't cover the extra parts why not the warranty? I was told my warranty covers everything on the outside of the car.
They also told me I needed the Brake Fuel Exchange. I called back 10 min after I left asking them not to do it and the person at the service department said they would tell my service rep but apparently did not. I gave them all my car information and my cell has a log of the phone call. Is this ok for them to do this? If I knew the person would not I would have said no let me speak to the service rep myself.
The Brake Fuel Exchange was $99 and $17 for the Brake Fluid. Why the extra $17 for brake fluid if I'm already paying $99 to exchange the brake fluid?
Any info is greatly appreciated!
True they nickel and dimed you but that is typical at a Stealer. Find a good independant shop.
Lou K
Several And various Autos
Lou K is offline
post #13 of 20 (permalink) Old 11-13-2010, 01:26 PM Thread Starter
Date registered: Nov 2010
Thanks everyone for the info! Just wanted to make sure the invoice wasn't off the beaten path.
10001 is offline
post #14 of 20 (permalink) Old 11-14-2010, 04:04 PM
Date registered: Jan 2004
Quoted: 30 Post(s)
Brake fluid is supposed to be changed every two years, not just looked at. You can't tell by just looking at the fluid if it is bad. You are asking for trouble and more expensive repairs if you go 6 - 10 years without changing it.
Len
'59 220S Cabriolet - for sale - http://www.mbzponton.org/mbz220s/sellswap/car4sale.htm
'83 240D original owner 351,500 miles - sadly I let it go
'88 560SL 41,000 miles being parted out - https://sites.google.com/site/mercedesstuff/home
'99 E300 turbo 206,000 miles
'03 SLK320 37,500 miles
'14 Smart electric 8700 miles
sokoloff is offline
post #15 of 20 (permalink) Old 11-15-2010, 12:52 PM
Vehicle: CLK200 (W209), R33 Skyline
this is interesting
here is my breakdown for 77k miles Service B
-changed oil, oil filter and sump washer
-replaced pollen, air and fuel filters as required
-checked all lights and replaced bulbs as required
-greased door locks and hinges
-checked all levels and tyre pressures
-checked brakes
-ran system diagnostic
-road tested vehicle
-reset basic settings
-reset service interval and stamped service book
-brake fluid change
CAR REQUIRES 2 FRONT SUSPENSION ARMS AND BUSHES
was also charged for 3 Filters, again a washer? w/shield washer soln, brake fluid, a bulb and 5L of engine oil
580 EURO
For my next Service A at 92K miles I moved to another MB garage and was told the timing chain needs replacing. Which was a surprise a) having been told the chain unlike a belt does not need replacing just a tension tighten and b) because there was no mention of the suspension issue. However I went and had the replacement done. I lost about 2L of oil on my driveway overnight after the car was ''fixed and returned''. Had the car back to the garage and sure enough it was taken to be repaired again.
Now my situation is low compression in cylinder 4.
http://www.benzworld.org/forums/w209...ml#post4438057
Funny as I was asking about changing brake fluid and servicing myself in future if possible.
elsnooty is offline
post #16 of 20 (permalink) Old 11-15-2010, 01:35 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 375 Post(s)
Please explain to us all WHAT has degraded the brake fluid, and how this happens in a closed system.
(I am not considering driving down the side of a mountain and boiling the fluid by constant braking either!)
keyhole is offline
post #17 of 20 (permalink) Old 11-15-2010, 03:42 PM
Quoted: 30 Post(s)
The brake fluid will absorb moisture from the air. DOT3/4 fluid will absorb the moisture. Moisture will reduce the boiling point of the brake fluid which is one issue. Moisture if left in the system will find its way somewhere that you don't want it and can damage some pretty expensive parts. I opt to follow the recommended service requirement and spend ten bucks every two years and flush the system rather than wait until I have to spend thousands to replace the ABS unit or the booster or the master cylinder or the calipers or whatever. Everyone makes a choice on what service they feel is necessary. I tend to be conservative and follow the recommended intervals, since I'm positive that I don't know more about it than the engineers who designed it. My latest Mercedes is an "03, so that's the latest service information I have. What does your manual tell you about yours? Maybe that interval has changed?
Len
sokoloff is offline
post #18 of 20 (permalink) Old 11-15-2010, 05:31 PM
keyhole's Avatar
Quoted: 375 Post(s)
Yes - we know it is hygroscopic. But the brake fluid is trapped between the piston in the master cylinder and the piston in the brake caliper. There is no air in there! And I said that I was not concerned with boiling the fluid - we are not talking about racing cars!
I concede that my Service booklet (2004) agrees with yours for a flush every 2 years.
But in my view that is unneccessary. I've owned and maintained cars since the 1960s and only flushed brake fluid when I've done major work on calipers, etc.
My A service requires a reservoir level check, and for the B service it's all the brake pads thickness that are checked. No flush called for there.
keyhole is offline
post #19 of 20 (permalink) Old 11-16-2010, 11:21 AM
Ive 2003 also and says similar to whats detailed ^^^^
do you change this yourself and if so any tips.
elsnooty is offline
post #20 of 20 (permalink) Old 11-16-2010, 11:56 AM
Quoted: 30 Post(s)
Pressure bleeder makes it a snap and a one person job. There are several flavors of pressure bleeders. I use the Speedibleed, Brake Bleeding Made Easier With Speedi-Bleed Brake Bleeder Tool
Len
sokoloff is offline
    Invoice for B Service bcr4d General Mercedes-Benz 7 02-19-2010 10:11 AM
    Service Invoice dahappybanana W163 M-Class 4 08-26-2006 08:49 AM
    Dealer invoice spinsonic C219 CLS-Class 16 04-22-2006 10:40 PM
    Original Invoice Peteski General Mercedes-Benz 5 04-27-2004 03:25 PM
    Invoice pricing AutoSaurus W211 E-Class 0 09-07-2002 01:58 PM
