1998 420 S Poor Radio Reception - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 11-11-2010, 10:17 AM Thread Starter
Date registered: Nov 2010
The antenna fell off the vehicle several years ago. $700 later, a new antenna was installed but with very poor radio reception. Yesterday the damn antenna fell off again, however was still hanging by the plastic gear. I was able to feed the plastic gear back through the motor and have it connected and operating again, but now the reception is even worse. I tried bypassing the combiner box and connected the radio co-axil directly into the neck of the antenna housing, but this did not help. I noticed that the "rubber wedge nut" that mounts to the outside of the vehicle has maybe a 2-3" bent stiff wire that protrudes out of the rubber stop and into the vehicle. I don't know what this does and/or if it is broken. Everything is stock, no aftermarket radio/antenna's are used. Any suggestions that would help increase the radio reception would be appreciated.
valtski is offline
post #2 of 3 (permalink) Old 11-11-2010, 10:40 AM
Musikmann's Avatar
Quoted: 6 Post(s)
MB calls your car a W140 and there is a dedicated forum for those. Just scroll down from this general forum until you see the sedans section. There are bound to be other like owners who have had a similar problem. Good luck and welcome.
Musikmann is offline
post #3 of 3 (permalink) Old 11-11-2010, 12:54 PM Thread Starter
Thank you
I will check the sedan section
valtski is offline
    Poor radio reception Thomasbhughes C208/A208 CLK-Class 1 07-05-2008 11:39 AM
    E-320 poor radio reception jnstro W210 E-Class 6 04-30-2008 06:30 PM
    Poor radio reception? Read this... hishamz W210 E-Class 1 12-08-2005 12:14 PM
    Help with Poor AM Radio Reception. elladdin W163 M-Class 10 11-08-2004 08:32 PM
    Help with Poor AM Radio Reception. elladdin W163 M-Class 0 11-04-2004 06:11 AM
