1995 S320 Transission shift repair - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 11-04-2010, 06:34 PM Thread Starter
Date registered: Nov 2010
Vehicle: 1995 S320
I recently replaced the transmission overload switch as it was leaking through a small port hole in the switch. When i pulled the switch out the B1 brake band Thrust element or Thrush bearing element came out with it. there is a small thrust pin attached to the end of the element that is secured to the element by a round plastic clip. The clip fell apart in peices. I had to order a new plastic clip and 2 rubber O rings. As we were at a freinds house and I could not get the pin back in we re-inserted the elemnet with out the pin. The car drove ok accept that I had to pull my foot of the gas pedal in order for it to shift out of 1st gear.
I got a new clip. Put the pin back in and reinserted the thrust element agian.
It was hard going in and I thought I heard a crush or snap as it was being pushed in with Overload switch. I pulled it back out and the pin was still attached, so I inserted it again. I have no fluid leaks but the car now again revs very high and then you let up on the gas and it will shift.
Any clue to what the problem and remedie are?
Did I damage the pistin on the ather side of the B1 Band.
I failed to check the spring in the Thrust element to see if I broke it but it looked like a pretty heavy spring.
getmore is offline
    96 s320 gear shift lights are out...... OCMD W140 S-Class 12 12-29-2010 11:38 AM
    Transission shift between W/S mode TGates615 W203 C-Class 0 07-09-2009 01:29 PM
    1995 S320 pzora General Mercedes-Benz 0 11-20-2008 11:10 PM
    1995 s320 jimmy9299 W140 S-Class 1 08-04-2007 10:35 PM
    1995 s320 Old Otto W140 S-Class 7 04-30-2005 01:20 PM
