1988 Mercedes SLI560 transmission leak/question - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 11-02-2010, 06:46 PM Thread Starter
Date registered: Nov 2010
I have aquired this car and I have a problem with the trans; the front seal is leaking. I know I will need to pull the trans down, but I need to know if there are any special tools required to change the seal. This will be my first time doing any kind of work on a mercedes but it shouldn't be a problem as long as it's the same as any other car by simply removing the converter and popping the seal out with a seal tool. Thanks in advance.
Also: I meant SEL not SLI, sorry guys.
Rocket9k is offline
    1988 260E transmission swap question 88BenzBoy W124 E,CE,D,TD Class 1 06-30-2010 10:58 AM
    1988 560 SL Transmission Leak? Ella R/C107 SL/SLC Class 1 03-31-2009 04:31 PM
    Transmission Leak question edwardgwright W126 S,SE,SEC,SEL,SD,SDL Class 2 05-20-2008 07:00 AM
    Transmission question on 1988 300SE mexicocrow W126 S,SE,SEC,SEL,SD,SDL Class 13 01-17-2005 06:36 AM
    coolant leak in 1988 mercedes 300se gogolfing W124 E,CE,D,TD Class 0 08-18-2002 06:51 PM
