Fan Pulley Problem - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 10-29-2010, 03:54 PM Thread Starter
Date registered: Oct 2010
Fan Pulley Problem
I have an 88 300E, about 160K miles. The fan pulley has decided to go out of whack, and is out of vertical, with the bottom closer to the block than the top. That is causing it to rub on an unrelated bracket, making a heck of a racket and tossing flecks of metal around the engine compartment. I can move the pulley back to vertical with my hand and wobble it around. I have no idea where to start to fix this. Anybody else had this happen? Kind of bizarre. Thanks.
crengel is offline
post #2 of 5 (permalink) Old 10-29-2010, 06:02 PM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 86 Post(s)
I bet it is time to replace it. Mine actually broke free and found the radiator. (different model but same engine as yours) Autohausaz will have the parts. Check the back of your fan clutch to see it any of it has broken. I have a feeling it has.
Mike
Michael Pillay is offline
post #3 of 5 (permalink) Old 10-29-2010, 06:22 PM
Thorgod's Avatar
Date registered: Jul 2005
Vehicle: 2013 SL550 Grey/ Red/Black Ash wood with every option
Quoted: 4 Post(s)
Bearing Bracket
crengel, I would speculate that the problem is the bearing bracket (pictured below). Please take the time to fill out your profile with all pertinent info, especially location. You might have an MB tech or more knowlegable forum member living nearby. Also the blue stickies at the top of each forum are filled with endless info, and the "search this thread" can provide a world of additional help. If it were my car I would be replacing: Bearing Bracket, Fan Clutch, Belt Tensioner, Accessory Belt Tensioner Shock, Belt, Thermostat, Coolant and maybe even the water pump. You're there now, may as well do it all. Let us know..............Thor
1971 350SL 4-speed stick- sold
1979 300CD- sold
1979 450SL (Euro)- sold
1985 300D- sold
1989 560SL- sold
1994 E320 wagon- sold
1995 SL500- 46,000 mi.- sold
2004 Land Rover Discovery- sold
2009 SL550- Silver Arrow- 26,275 miles- sold
2013 SL550-
Thorgod is offline
post #4 of 5 (permalink) Old 10-29-2010, 06:39 PM Thread Starter
Thank you gentlemen. I've had this car for 3 years and have had to do nothing to it. This is my first foray into the engine compartment, of any substance, and I have no idea what I'm doing. Quite a bit different than my old Ford truck. I'm dead bottom of the learning curve at the moment, but it's steepening quickly. I am assuming it's the bearing bracket, which makes perfect sense. We'll see about the other stuff. I'm sure I'll be back to this thread over the next 24-48 hours with further stupid questions.
Thanks again.
crengel is offline
post #5 of 5 (permalink) Old 10-30-2010, 07:25 AM
Quoted: 86 Post(s)
Here's what happened with mine:
http://www.benzworld.org/forums/w126...-pump-but.html
It is not hard to do really. How bad are the fan blades at this point? It you get the bracket and clutch you will probably be okay. Check your belt too for wear. You just need to address this soon. If you need the pdf on doing some of this work, pm me. I have a paper copy but I should have the pdf saved somewhere.
Mike
    radiator fan pulley slackerguy W163 M-Class 12 03-05-2014 07:53 PM
    Remove pulley/fan from alternator... jroquet W126 S,SE,SEC,SEL,SD,SDL Class 11 12-30-2013 06:42 PM
    Viscous Fan Clutch and Pulley viejo1221 W201 190-Class 0 06-11-2009 12:13 PM
    Update: Fan Hitting Crank Pulley....... NorCalSL R/C107 SL/SLC Class 10 08-31-2007 10:49 PM
    M103 Fan Belt Pulley Problem samfatboy W126 S,SE,SEC,SEL,SD,SDL Class 5 07-12-2007 10:55 PM
