96 odometer mileage clock constant on - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-29-2010, 06:16 AM Thread Starter
Date registered: Oct 2010
Hello:
I have a 1996 e320 with a l6 3.2 liter engine 150,000ish miles. The odometer , mileage, temperature and clock on the cluster stay constantly lit even after several minutes with the key removed from the ignition. The battery was replaced recently but the customer does not remember this being lit constantly. Any suggestion as to a cluster failure or another issue would be great as I am not very fluent with euro’s.
Thanks.
jefb is offline
post #2 of 2 (permalink) Old 10-29-2010, 07:47 AM
Musikmann's Avatar
Quoted: 6 Post(s)
I'm not fluent with these either but I can suggest you scroll down to the W210 forum found in the sedans section. There are a few real "whiz kids" who can probably help you. Just a WAG: the car evidently thinks the key is still in the ignition so I would suspect something with the ignition system like in the tumbler mechanism. Good luck.
Musikmann is offline
    Odometer and trip mileage not working 300seTexas W126 S,SE,SEC,SEL,SD,SDL Class 11 07-19-2010 01:34 PM
    1/2 Dim Temp/Odometer/Clock Display EasyE430 W210 E-Class 4 04-29-2010 11:27 PM
    U1300L Mileage (odometer reading) Oldmog Unimog 4 08-01-2009 10:45 PM
    How to adjust mileage on odometer??? jtoma878 W123 E,CE,D,CD,TD,TE Class 3 01-07-2007 09:00 AM
    Initial mileage: What was your odometer reading? reallife R171 SLK-Class 44 09-11-2006 02:46 PM
