wierd "check lamp" - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 10-27-2010, 05:09 PM Thread Starter
Date registered: Sep 2010
wierd "check lamp"
I double checked all lamps (front, side, rear, brake, plate lights, in door, front and rear in roof..). First I had check lamps message wehn I turned ON low light (it was plate lights and break lights) but now, I start the car and lights, turn every light, no malfunction message stands on screen, and then when I turn OFF lights, check lamps malfunction appears...
Does anyone know why ?
CLK 230 Kompressor year 2002, W208 model
voi1234 is offline
post #2 of 5 (permalink) Old 10-27-2010, 06:56 PM
Date registered: Jan 2010
Vehicle: E 550 4 matic 2010
how about parking lights and reverse lights and emergency flashers?
2010 E550 4matic, AMG Package
cerbomark is offline
post #3 of 5 (permalink) Old 10-28-2010, 04:51 AM
Date registered: Aug 2008
Vehicle: 2000 CLK 430 Cabriolet 2003 S500 4Matic 2004 S55 2005 CLK 500 Cabriolet 2008 S 450
Quoted: 63 Post(s)
I had a similar problem with my CLK 430. I'm told the system is so sensitive that it can predict an impending bulb failure due to the increasing resistance. If there is no burn out yet my experience proved that there soon will be.
mrbobby is offline
post #4 of 5 (permalink) Old 10-28-2010, 10:03 AM
yes true... even if a bulb is working but making a weird connection. I ve had it happen to me.
post #5 of 5 (permalink) Old 09-13-2012, 11:07 PM
jaycky's Avatar
Date registered: May 2012
Vehicle: 2000 CLk430
Guess that's my issue then everytime I put it into reverse I get a check lamp on gauge nothing out yet but I have replaced a few rear lamps now!
I will change everything out tomorrow on the back of the vehicle!
It's hit and miss Somedays it does it more than others,
Usually it's the little mid lights up front that go on me they seem to last a month and that's it!
jaycky is offline
    "CHECK LAMP!" issue 420SELGUY W220 S-Class 10 05-04-2016 05:51 AM
    '89 560SL "Check Engine" lamp coming on Christopher Winkels R/C107 SL/SLC Class 7 06-16-2010 05:24 AM
    1999 E320 "Lamp Defective" but all bulbs working vacant_lot W210 E50 AMG, E55 AMG 2 09-16-2009 08:24 PM
    Keep getting "Check Gas Cap" warning message and now have check engine light, help?! timmynabenz C209/A209 CLK-Class 2 03-25-2009 10:56 PM
