Foam Filters - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 10-17-2010, 07:38 PM Thread Starter
Date registered: Oct 2010
Vehicle: 06 C230 Sport
Foam Filters
I was wondering if anyone has a foam filter in their car. I have looked all over the Forum, and all I have found is discussion on K&N. I am concluding K&Ns are good for flow but bad for protection. Plus there sounds like the possibility of MAF sensor issues. I currently have K&Ns in my 06 C230 but am considering taking them out and replacing them with OEM filters (sucks because they are not cheap). However, before I do I wanted to see if anyone has had any experience with foam filters.
Also, any recommendation on where you can buy OEM parts online.
C230TN is offline
post #2 of 6 (permalink) Old 10-17-2010, 07:56 PM
SHAUNE55's Avatar
Date registered: Aug 2010
Vehicle: 2001 E55 AMG
Quoted: 4 Post(s)
I have piper cross foam filters.
SHAUNE55 is offline
post #3 of 6 (permalink) Old 10-17-2010, 08:49 PM Thread Starter
Do you like them? Are they hard to clean? Any issues with CEL or MAF sensors?
C230TN is offline
post #4 of 6 (permalink) Old 10-17-2010, 08:53 PM
SHAUNE55's Avatar
Quoted: 4 Post(s)
Not needed to clean them yet,I've got a PDF on cleaning them.....No problems with CEL or MAF........Yes I like them,maybe it's all in the mind but I just don't like paper ones!
SHAUNE55 is offline
post #5 of 6 (permalink) Old 10-17-2010, 09:18 PM Thread Starter
I understand the feeling. I don't like the paper one either, so I got some K&N but after doing some research (after the fact) it seems K&Ns are not all they are cracked up to be. From my research it sounds like foam has the best filtration of them all, so maybe I will try them. Thanks for you input.
C230TN is offline
post #6 of 6 (permalink) Old 10-17-2010, 09:27 PM
SHAUNE55's Avatar
Quoted: 4 Post(s)
I spent a while doing research,various video demos and reading, changed my mind back and forth and went for the foam...Why?....Not 100% sure, seemed better filtration than K+N, also figured they will be easier to clean, plus when you look in to the actual structure of the foam it just seemed better...I may be wrong.
SHAUNE55 is offline
    Cabin filters and fuel filters, replace? crashtest General Mercedes-Benz 7 12-19-2009 01:54 PM
    Changing cabin air filters and charcoal filters instructions George993 W210 E-Class 13 06-28-2009 09:46 AM
    stock air filters vs oiled filters test oberoi R170 SLK-Class 10 11-12-2008 11:53 AM
    seat foam 0well W123 E,CE,D,CD,TD,TE Class 4 03-01-2008 06:51 PM
