New Member with vito glow plug problem - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-17-2010, 08:20 AM Thread Starter
Date registered: Oct 2010
I've just bought a Mercedes 2000 with a rev limiter that won't rev over 3000. Plugged it in came up with the following codes:
P1481 Glow plug failure
P1636 Electric suction fan
P0105 Pressure manifold absolute pressure sensor
P0703 Stop lamp
P1470 Charge pressure control sensor
found that the MAP sensor was broken off so thats that sorted.
started with the glow plug and found that the centre was missing, the bit that the plug clicks onto, so undone the body of the glow plug which came out leaving the tip of the glow plug in the head. it's very tight.
Can this be removed with a glow plug remover? or would the tip fall into the head if left and just capped off with a bolt?
Any ideas??
Does anyone know what and where is the electric suction fan, code P1636. Also Charge pressure control sensor, Code P1470.
Thanks,
Wakevla
wakevla is offline
post #2 of 2 (permalink) Old 10-19-2010, 12:21 AM
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 210,xxx Miles
Quoted: 6 Post(s)
leapyfish is offline
vito glow plug & EDC light on??? kevin evans V-Class 8 04-28-2011 01:46 AM
glow plug problem brownrice78 W123 E,CE,D,CD,TD,TE Class 8 03-13-2009 10:52 AM
VITO 108 CDI Glow plug / coil light bulb removal JD-SMART-REPAIR General Mercedes-Benz 0 11-20-2008 12:36 PM
vito 110cdi Glow plug light fixed hipringle V-Class 3 10-25-2008 01:29 AM
Glow plug problem....again... ericp W123 E,CE,D,CD,TD,TE Class 11 10-17-2007 04:24 PM
