A160 BAS / ESP Cable Short - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-16-2010, 10:49 AM Thread Starter
Date registered: Oct 2010
Angry A160 BAS / ESP Cable Short
Hi Guys, ok yes i am another with the dreaded /ESP error. So far i have changed battery, brake sensor, checked wheel sensor and i'm pretty sure i have found the issue!!!!!
The error was showing something to do with earthing (cant remember what as i thought i have fixed it 4 or 5 times by now, as its been intermittent), anyway ive just removed the ECU to check if this is the issue and found....
The main wiring loop that runs behind it has rubbed the outer sheaf and worn 1 of the wires protective plastic sheaf down to bear wire!!!
I can only see 1 wire damaged so its not shorting, but i guess it could effect the electrical signal if the wire has thinned (which it has)...
So my challenge now is - how do you repair the wire without effecting the through signal.
PS im a helicopter tech, so please excuse my lack of vehicle knowledge. in avionics we just have to replace any loom, which is NOT what i want to do on my poorly car.
All help welcome!!
itsStorm is offline
post #2 of 2 (permalink) Old 10-16-2010, 04:41 PM
Date registered: Jan 2007
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
repairing the wire is cake. cut out the damaged section of wiring and solder in a new wire. if the repair is done good your signal will be fine.
Streetglower is offline
    A160 BAS-ESP Ahronos W168 A-Class 28 05-03-2011 12:01 PM
    BAS/ESP help!! KIKEJUNIOR W163 M-Class 1 08-25-2009 12:42 PM
    ESP + BAS rakan.maddah W203 C-Class 0 07-10-2009 06:59 AM
    BAS Esp & ESP Lights Up... amflip W163 M-Class 6 09-23-2007 07:32 PM
    BAS/ESP O Dogg W163 M-Class 9 08-04-2004 07:09 PM
