Transmission problem - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-16-2010, 08:35 AM Thread Starter
Date registered: Oct 2010
Hi,
I have a 2003, E320 and transmission only shifts up to 3rd gear...not higher...and when stopping, stays in 3rd gear unless I turn the engine off. than again starts From 1st gear and only up to 3rd gear only....
Do you think it is the transmission or electronic control computer of the tranny..??
Thank for your replies.
alvand is offline
post #2 of 2 (permalink) Old 10-16-2010, 10:44 AM
Kajtek1's Avatar
Quoted: 1169 Post(s)
You need to take the car to a shop with Star computer to read the transmission codes.
Your car has W211 body? Go to appropriate section for more accurate replies. Actually you might have the same 5 sped transmission W210 have so you can check there as well.
Welcome to the forum
Kajtek1 is online now
    Do I have a transmission problem? Bubbabear1980 W124 E,CE,D,TD Class 16 10-29-2010 01:03 AM
    Transmission Problem sagamol W124 E,CE,D,TD Class 4 04-04-2010 11:42 AM
    Transmission problem? TPS Problem? NOLA911 G-Class 29 10-28-2009 02:30 PM
    transmission problem? krystal640 W210 E-Class 8 08-06-2009 06:42 PM
    Brake padal vibration problem + transmission problem Majid Mansoori W210 E-Class 11 09-22-2003 08:33 PM
