w210 300td abs bas asr warning lights on - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-15-2010, 09:54 AM Thread Starter
Date registered: Sep 2010
Help ABS and BAS warning lights on all the time when ignition switched on. Fault appeared when vehicle left standing for several days. I have replaced following :- battery with a decent heavy duty exide one, brake light switch from MB and regulator in alternator. Also tried leaving battery disconnected over night to reset ecu and turning steering full lock and yet fault still there. all thoughts appreciated
brickwork is offline
post #2 of 3 (permalink) Old 10-23-2010, 11:07 AM Thread Starter
found fault
Having searched the forum decided to check speed sensors and bingo front right sensor wiring was chaffed? bent cable and all warning lights went out
post #3 of 3 (permalink) Old 10-23-2010, 12:03 PM
Kajtek1's Avatar
Quoted: 1250 Post(s)
Love the simple solutions
Kajtek1 is online now
    BAS, ASR, ABS Lights on, w/C1401 code tiffe320 W210 E-Class 29 01-29-2015 11:16 AM
    Troubleshooting ABS and BAS/ASR lights andyman32 W140 S-Class 2 11-08-2012 05:24 AM
    BAS, ASR and ABS lights... Northernstar002 C208/A208 CLK-Class 28 02-13-2011 10:18 AM
    BAS/ASR and ABS lights on, mcgvs C208/A208 CLK-Class 7 06-22-2010 01:49 PM
    ABS & BAS ASR lights on ccrobins The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 06-30-2006 01:28 AM
