E320 Rear Passenger Side Window Won't Roll Up - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-12-2010, 08:14 PM Thread Starter
Date registered: Jul 2009
Vehicle: 2000 E320, 1999 Dodge Ram Conversion Van, 2000 GMC Sonoma Pickup
2000 E320 - So my daughter returned with my car the other night and the rear passenger window is stuck in the down position. I can hear the motor running in there when I press the button to raise it, but nothing happens. I checked out the archive and found a few helpful posts about other models, but wanted to see if someone could point me towards something more specific to my car. Pictures or videos would be awesome if someone has them. I am fairly mechanically inclined and would like to tackle this on my own if it's doable.
Cheers!
Punkinapple is offline
post #2 of 2 (permalink) Old 10-12-2010, 09:15 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Yes it is doable and a common problem on the W210. Look in the sedans section for our W210 forum and you will find the solution for a broken window regulator fix in the sticky threads. You should see those at the top of any of the pages.
Musikmann is offline
    Rear passenger side panel for window arashsheikhpoor15 C208/A208 CLK-Class 4 04-27-2015 07:39 PM
    Rear Passenger Side Window Malfunction poehlsDC W124 E,CE,D,TD Class 3 09-23-2008 03:42 AM
    Need new Rear passenger side window alexgreggs C215 CL-Class 0 05-08-2006 09:58 PM
    Power window rear passenger-side SParkyMerc W126 S,SE,SEC,SEL,SD,SDL Class 7 01-04-2006 12:22 PM
    Passenger Side Rear Window Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 8 11-19-2004 10:00 AM
