1980 300sd won't start after filter change. - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-06-2010, 11:35 AM Thread Starter
Date registered: Oct 2010
After reading post after post i finally got the car to start but not for long. I've filled the filter with fuel, pumped the primer, and cracked the nuts at the injectors. I even bought a new battery to give me some more cranking power. Now when it starts it only runs with the the pedal all the way down, when i let up it dies. I'm going to change the strainer in the fuel tank and see what happens. Any thoughts?
mmjavidi is offline
post #2 of 3 (permalink) Old 10-06-2010, 11:43 AM
Kajtek1's Avatar
Quoted: 1070 Post(s)
You still have air in the lines. It takes some time. Keep it running with pedal on the floor till it run smoothly. Also having the front down helps.
You filled up the filter with contaminated fuel and let it run into injectors?
Hope this is not what costing the problem.
Check for the really proper procedure next time.
You should have bleeding screw on the top of the filter housing, so putting clean filter, opening the bleeder and hand priming should be the right start.
Kajtek1 is online now
post #3 of 3 (permalink) Old 10-06-2010, 12:17 PM Thread Starter
the fuel I put in the filter was clean, when i floor it too long the car starts to overheat, and what do you mean "have the front down"?
mmjavidi is offline
    oil/filter change and now wont start noShame W202 C-Class 0 09-26-2007 09:34 AM
    1980 240D wont start after fuel filter replacement? Rangelic W123 E,CE,D,CD,TD,TE Class 9 06-14-2007 09:53 AM
    1980 300SD won't start. . . . LexTron6K W116 S, SE, SEL, SD Class 4 01-01-2007 10:06 PM
    diesel wont start after fuel lines and filter change biodieseler W210 E-Class 6 10-29-2006 07:10 PM
    1980 300sd won't start nckmsn W126 S,SE,SEC,SEL,SD,SDL Class 6 12-06-2005 01:40 PM
