CLK430 starting problems - Page 2 - Mercedes-Benz Forum
post #11 of 14 (permalink) Old 04-08-2011, 09:40 AM
mbvis's Avatar
Date registered: Jan 2010
Vehicle: 99 E430, 01 E430 Sport, 00 SL500
Quoted: 2 Post(s)
Most everyone knows the easy part is an E8 socket to fit. The hard part is what tool to use to remove/re-install in such a tight space where the eyes can't see nothing.
mbvis is offline
post #12 of 14 (permalink) Old 07-27-2012, 04:23 PM
Date registered: Oct 2007
Vehicle: '99 CLK 320 Coupe
Replacing the Crank Position Sensor (using a dab of Superglue on the bolt!)
Last night, after receiving a somewhat frantic call from a female friend, I had the "pleasure" of replacing the CPS on her '01 CLK 430 using the above helpful information. Thanks to all the forum folks who posted above. I have to add that doing this at night in Los Angeles, in the less-than-friendly confines of a gas station parking lot was not my idea, but when cars breakdown and friends call, you don't have much choice.
I have a '99 CLK 320 and looked at my V6 to get an idea of what is needed to do the R&R. The location of the sensor makes getting your hand in there with a socket a challenge. My biggest concern was dropping the small screw into the engine compartment and losing it. Through trial and error and a limited access to tools, I settled on a 6.0mm 1/4" drive six-point socket, 3" & 6" 1/4" extensions, 1/4" universal joint, 1/4 to 3/8 adapter and 3/8 ratchet. I also used a really bright LED flashlight and a 1x3" inspection mirror to help locate and line up the socket to the bolt.
On the 430 luckily the electrical connection has a single "push to release" connector, so that came off first with little fuss. (my 320 has a more difficult two point release). Next I fished the 6.0mm socket onto the star-headed bolt, with the 3' + 6" 1/4" extensions attached to the socket. Once I felt the socket land on the bolt, I attached the universal joint, 3/8 adapter and ratchet to loosen the bolt. It only takes a quarter turn to make it loose, which then made removing the bolt a one-handed operation. I tried putting some ABC gum on the socket which kept the bolt from falling off. There's very little wiggle room because of the heat shield that nearly blocks access to the bolt so this is trickier than it might appear at first.
Out came the old sensor and in went the new one. I then used SUPERGLUE to attach the bolt to the socket. Might be overkill, but I was not looking to spend a night in LA if I didn't have to and the tape or grease methods didn't seem as foolproof for me. I was miles from home and if that bolt got lost at 10pm, I was not going to be really happy.
Getting the bolt lined up with the sensor and the threaded hole in the back of the engine took a few minutes since there isn't a detent or flange to help locate it. But once it was in and tight, the superglued socket came off of the bolt easily. The electrical connector replugged with a definitive click and all was good. The engine started and the problem was solved.
The intermittent engine stalling on the car should have been dealt with as soon as it started a few weeks earlier, so as a word of caution to anyone with that problem, I'd highly recommend getting the sensor ($54 at Autozone or Oreilly's or a bit less at and do the swap in the comfort of your own garage. I found the 1/4" extensions, U-joint and a $9.99 socket set that included the 6.0mm 1/4" socket at my corner auto parts store. I didn't have the time to fiddle with my 3/8" drive star sockets and with so little room, I took the above poster's advice and went with the 1/4" tools.
I have a cheapie OBD-II scanner, but for some reason it doesn't work on the '01, just on my "99, so I wasn't able to read what the error codes were, but the car now runs fine and by disconnecting the battery to do an Okie code reset, the Check Engine light has gone out after the engine starts.
Thanks again to the many helpful posters in this forum. You've saved me countless dollars and hours of trial and error on a host of minor issues and maintenance. My '99 CLK 320, now with 104k on it, has been extremely reliable and trouble-free, fingers crossed, it will stay that way.
jvfante is offline
post #13 of 14 (permalink) Old 07-12-2015, 03:28 PM
CoffeeGuy14's Avatar
Date registered: Dec 2013
Vehicle: 2003 CLK320 Cabriolet
Quoted: 5 Post(s)
The Legacy Of An Old Thread ..
Time to change the CPS and it seems intimidating to a still-learning DIY mechanic.
I've verified a Crankshaft Position Sensor failure, the symptoms are right, I've gathered the suggested tools and gone through a couple of 'dry-run' practice repairs.
I'm building my confidence instead of calling my mechanic. The best way to ace a test is to be prepared. And I'm preparing to save about $400 (and that's cheaper than most I've read about).
This old thread is exactly what I needed to see right now. I'm pulling the trigger and ordering the Bosch OEM part on Amazon tonite.
Wish me success!
CoffeeGuy14 is offline
post #14 of 14 (permalink) Old 07-18-2015, 01:13 PM
Quoted: 5 Post(s)
Successful CPS Repair!
Took me about an hour to replace the part. Hardest part for me was getting that torx bolt restarted. (Not being able to see what you're trying to screw in - or even if the holes line up - was nerve wracking!)
But patience and tenacity prevailed. I'm driving top-down this morning and smiling big knowing that I saved nearly $400 doing this myself.
  • Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
    2000 Clk430 problems benzoclk_430 C208/A208 CLK-Class 1 09-08-2010 05:01 PM
    CLK430 key problems doccherry General Mercedes-Benz 1 04-13-2010 02:32 PM
    Stored 1993 S420 has fuel problems-Gives sudden starting problems-solution needed heartmd W140 S-Class 15 12-09-2007 01:45 PM
    Big problems CLK430. MDCLK430 General Mercedes-Benz 9 11-28-2006 09:47 AM
    anyone have starting problems? My car died twice today after starting... cgeorge430 W163 M-Class 10 08-03-2002 10:57 PM
