SL500 Mass air flow sensor - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-04-2010, 02:36 PM Thread Starter
Date registered: Oct 2010
I need a procedure for replacing the MAF (mass air flow sensor).
Slaf is offline
post #2 of 3 (permalink) Old 10-05-2010, 11:23 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
See STAR TekInfo
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #3 of 3 (permalink) Old 10-05-2010, 02:25 PM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 81 Post(s)
Do you know where the sensor is located? I am not familiar with your specific engine but if you do not know the location, start at the air filter housing and follow the plastic pipe until you locate the MAF. It should have an electrical plug in on the side. Disconnect the electrical connector. Most MB engines have a worm drive clamp the will need a screw driver or socket to loosen and the other end usually has a clamp that sort of pops up to release. You should be able to remove the MAF after that. If you intend to remove the actual sensor from the housing, check to see if it is held in place by torx security screws. If so, you will need torx security/tamper proof bits to remove it. This is all sort of general but hopefully it helps!
Mike
Michael Pillay is offline
    2000 SL500 Mass Air Flow Sensor msantus General Mercedes-Benz 1 05-04-2010 03:19 PM
    94 SL500 mass air flow sensor majorcynik R129 SL-Class 2 03-11-2009 03:09 PM
    Mass Air Flow Sensor schmora15 For Sale/Wanted/Trade/Giveaway 0 01-15-2009 09:53 AM
    Cleaning the MAF Sensor Mass Air Flow Sensor Paul Mellerowicz W210 E-Class 9 09-07-2007 05:32 AM
    mass air flow sensor 247hoopsfan W124 E,CE,D,TD Class 0 07-10-2005 05:31 PM
