Help Needed. Starting problems, runs for a second and shuts off. - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 10-03-2010, 07:38 PM Thread Starter
Date registered: Oct 2010
Have a 1988 260e, its in great shape, but having trouble keeping the car running. It will start, run a few seconds and shut off. I can keep it running with carb cleaner, changed fuel filter and fuel pumps are working.
Any suggestions?
Webdez1 is offline
post #2 of 4 (permalink) Old 10-03-2010, 09:28 PM
nenad16's Avatar
Date registered: Aug 2005
when you say the pump works, did you jump it directly or you can hear it run with the key on? if you jumped it directly, and it runs while energized, I would look at the relay next.
I'm not a bad christian, I'm a good atheist.
nenad16 is offline
post #3 of 4 (permalink) Old 10-04-2010, 05:02 AM Thread Starter
Fuel pump
I here the pump running. Do you recommend jumping the connectors?
Webdez1 is offline
post #4 of 4 (permalink) Old 10-05-2010, 03:53 AM
nenad16's Avatar
check the fuel pressure.
nenad16 is offline
    78 280 CE Runs rough and shuts off sflcobra W123 E,CE,D,CD,TD,TE Class 3 01-08-2010 06:34 PM
    1990 2.6 shuts off right after starting ChuangTzu W201 190-Class 9 04-09-2009 09:27 AM
    Starts and runs for 3-5 mins then shuts off trob064 W201 190-Class 3 04-07-2009 09:13 AM
    Stored 1993 S420 has fuel problems-Gives sudden starting problems-solution needed heartmd W140 S-Class 15 12-09-2007 01:45 PM
    anyone have starting problems? My car died twice today after starting... cgeorge430 W163 M-Class 10 08-03-2002 10:57 PM
