Pls Help Engine quits when warm - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-02-2010, 10:25 PM Thread Starter
Date registered: May 2010
Vehicle: 1993 190e 2.6
1993 190e 2.6
Runs until hot then studders and quits at idle -won't restart until cold.
Installed new crankcase position sensor (Bosch 0 251 210 49) and engine won't start at all. Still starts with old sensor.
New CPS sensor measures 850 ohms. I've heard there may be two different sensors with different output...are these matched to the ignition module?
Suggestions please...going nuts over this. Some have even suggested the coolant temp sensor can cause this problem but that makes no sense.
What is going on? Why won't the new sensor work? Help please.
PaulBennett is offline
post #2 of 2 (permalink) Old 10-03-2010, 09:24 AM
Musikmann's Avatar
Quoted: 6 Post(s)
This might be a better question for your native forum. Look under the sedans heading and you'll see the W201 190 Class. Good luck.
Musikmann is offline
1999 E320 engine suddenly quits zdzich W210 E-Class 6 10-16-2009 05:20 PM
Pls Help - Need advice on replacing engine Moski W168 A-Class 0 09-05-2008 04:31 PM
engine swap-pls advise amars W124 E,CE,D,TD Class 3 03-16-2007 01:41 AM
Can we have updated stats on the engine/colour poll pls pls??? TXS and have a nice week everyone - MAX R170 SLK-Class 5 02-25-2002 11:03 PM
HELP ME PLS. 300SE engine cutout Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 1 05-13-2001 05:39 AM
