1999 c280 coolant flush/heater core - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 09-28-2010, 11:11 PM Thread Starter
Date registered: Sep 2010
Vehicle: 1999 c280
Exclamation 1999 c280 coolant flush/heater core
I need to service my coolant system ASAP -Sept. 28th-2010
This is my first German Vehicle.. I love it, and need to replace and repair many little things that the previous owner has neglected to.
w/133,000 miles
First thing is My Heater core. I Have taken out my carpet to dry and glove box. Next I need to know what the steps are to drain/FILL my fluid CORRECTLY.
*Symptoms*
- First I patched the cracked reservoir (ordering a new one)
- Refilled coolant
- Heater + AC work when full
- looses a Gallon in 2.5 miles
- doesn't overheat but heater blows cold and wet after 2.0 miles
- Air in all lines
- circulating to all hoses ( air + water from hand pumping hoses )
- Pollen filter has never been changed (very dirty)
- After driving 2.5 miles it leaks on roadway in steady streams ( also under cal. induct=dash/floor )
- No loss of power
- No smoke
- No present signs of head gasket being out
- I have yet to order a factory repair manual or plug into a diagnostics...
Help if possible thanks - Nick
1999 c280 is offline
    No circulation through heater core after coolant flush edoubleu W124 E,CE,D,TD Class 1 04-28-2010 11:56 AM
    Losing coolant / bypass heater core. sdoherty W124 E,CE,D,TD Class 4 04-05-2010 08:49 AM
    ? about heater core on '97 c280 jasfrost General Mercedes-Benz 3 01-09-2010 10:51 PM
    Another coolant leak question, Heater Core or Heater Core Valve?..... Nepenthe73 W201 190-Class 5 02-01-2009 05:18 AM
    Direction of coolant flow through heater core Stevenpfaff W123 E,CE,D,CD,TD,TE Class 0 01-29-2005 03:12 PM
