Relay switch - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 09-26-2010, 11:03 AM Thread Starter
Date registered: Jul 2008
Vehicle: SL500
Relay switch
Anyone know if and where the relay switch for the trunk is on the sl500 (2003). The trunk will not open unless the manual key is in the lock and turned, which leads me to believe that there is an electrical gap. But i could be wrong.
TIA
ZO6toSV is offline
post #2 of 3 (permalink) Old 09-26-2010, 07:35 PM
Date registered: Sep 2010
Vehicle: 2000 C280- 2000 E320 wagon
You have a possible vacuum pressure/supply problem for the lock. If the door locks work its not the pump. Probably a broken plastic actuator in the trunk lid. Listen for vacuum leaks at the trunk lid just behind the lisence plate. (may or may not be heard). Good luck.
SUBUYA is offline
post #3 of 3 (permalink) Old 09-28-2010, 12:54 PM Thread Starter
Vehicle: SL500
Thank You.
ZO6toSV is offline
    Mystery switch and relay RedLiner R129 SL-Class 4 03-29-2009 07:45 PM
    Window relay switch dhedhunter W163 M-Class 1 08-03-2005 08:46 AM
    ac relay switch gamer General Mercedes-Benz 1 06-22-2005 12:04 AM
    relay or switch? RuffStuff W123 E,CE,D,CD,TD,TE Class 0 10-26-2004 01:07 PM
    How can you tell if a relay switch is bad? Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 2 06-11-2004 06:07 AM
