Can someone identify this filler cap ? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 09-22-2010, 10:16 PM Thread Starter
hellgrace5's Avatar
Date registered: Feb 2009
Hi,
I have this expansion tank filler cap of W140 S500.
Part number #A 000 501 82 15
How many O ring should be attach with the filler cap ?
Mine came with only 1 " O " shaped O ring. And the O ring is quite loose not fit.
Someone told me it should be the square type O ring.
Exactly what kind of O ring should fit in it and how many ?
hellgrace5 is offline
post #2 of 3 (permalink) Old 09-23-2010, 08:59 AM
Kajtek1's Avatar
Quoted: 1197 Post(s)
Can't figure out what cap model it is, but caps work with compressed gaskets, so oring, or square -both will work if they are correct thickness. You should have only 1 oring for sealing the cap on the pipe, but the cap might have pressure valve build in it with more parts.
Kajtek1 is online now
post #3 of 3 (permalink) Old 09-23-2010, 10:29 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
If you live in USA you can look it up yourself here: http://epc.startekinfo.com
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
    Which side is your filler cap on? eric242340 Off-Topic 52 05-25-2010 09:10 AM
    Oil filler cap removal Musikmann W210 E-Class 20 02-19-2008 11:12 AM
    A class+filler cap cod W168 A-Class 1 01-20-2006 07:56 AM
    Fuel filler cap (Gas cap) types26/36/74 R170 SLK-Class 2 09-28-2005 01:46 PM
    Oil Filler Cap ychachad W140 S-Class 1 08-04-2004 09:32 PM
