'84 500SEL help!! former owner botched radio install...and... - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 09-21-2010, 07:41 PM Thread Starter
Date registered: Sep 2010
Vehicle: 1984 500 SEL
Former owner installed a radio in '84 500 sel. The radio stopped working today so I pulled it out. Several wires were adrift, some not protected from shorting out etc. I found that one of them was to the antenna through trial and error, and a couple fuses. I learned that the red is hot ant the brown is ground also. The center console lights aren't working, but I found a wire that turns them on by touching it to the hot wire, but have no idea where it should go. Please, can someone help me identify the proper wires, and where they go? The Air/heat does not work, and I am wondering if they may have messed that up too by their blunder.
Maybe I could reinstall a stock radio and solve the problem?????
thanks
shawnhoward is offline
post #2 of 6 (permalink) Old 09-21-2010, 09:11 PM
Date registered: Nov 2008
Originally Posted by shawnhoward View Post
Former owner installed a radio in '84 500 sel. The radio stopped working today so I pulled it out. Several wires were adrift, some not protected from shorting out etc. I found that one of them was to the antenna through trial and error, and a couple fuses. I learned that the red is hot ant the brown is ground also. The center console lights aren't working, but I found a wire that turns them on by touching it to the hot wire, but have no idea where it should go. Please, can someone help me identify the proper wires, and where they go? The Air/heat does not work, and I am wondering if they may have messed that up to by their blunder.
thanks
I'm interested in this as well, as a similar kind of muppet installed a new stereo at the expense of most of the electrics.
audihenry is offline
post #3 of 6 (permalink) Old 09-23-2010, 03:20 PM Thread Starter
you've been oh so helpful.... thanks
post #4 of 6 (permalink) Old 09-23-2010, 03:38 PM
What's with the sarcasm? We both have similar issues. Or is this thread only reserved for your highness?
post #5 of 6 (permalink) Old 09-23-2010, 09:06 PM Thread Starter
Please forgive me. The sarcasm was not meant for you at all. I just wish someone would give us some help. As a note... today I solved my radio problem, but still have two mystery wires remaining.
Blue and gray wire... connected to blue wire of aftermarket stereo= antenna goes up when radio turned on and down when radio turned off.
Red wire to stereo red wire: clock and preset memory
Red and yellow wire to stereo yellow wire: ignition hot wire
Brown wire to stereo black wire: ground
speaker wires were already hooked up and seem to work fine... I only have back speakers.
The "ignition hot wire" was dead... no current, so i lifted the fuse panel behind the firewall and noticed there was no screw on one side of the number 9 fuse. I disconnected the battery, and replaced the screw. I then had power and the stereo worked fine. (maybe the original stereo had a short and someone intentionally removed it?????)
As for my AC blower, I did find a hairline crack in the fusable link... it cracked half in two with a gentle touch. I will replace that, and tomorrow morning tear the blower motor out and see if it runs when hooked up direct. that should get me headed in the right direction i hope.
Again... please don't think i was trying to be rude to you... not meant to you at all... more directed toward the universe. I was getting very frustrated. I have been working on my patience for many years now.
post #6 of 6 (permalink) Old 09-23-2010, 09:25 PM
No problem Shawn, it's often difficult to convey things on the internet.
Looks like you've made some headway. I've only begun to assemble the parts!
500SEL Euro Headlight refurb/install (many pix) justinwrock W126 S,SE,SEC,SEL,SD,SDL Class 40 04-05-2010 05:19 AM
new 84 500sel euro owner!! nm450slc W126 S,SE,SEC,SEL,SD,SDL Class 15 09-29-2009 08:35 AM
Botched cremation mlfun Off-Topic 4 08-04-2008 07:28 AM
New Owner... 93 500SEL _Adrian_ W140 S-Class 4 05-10-2008 01:13 PM
New 500SEL Owner Surti85 W126 S,SE,SEC,SEL,SD,SDL Class 11 11-30-2002 04:40 AM
