C230 !997-- ETS, ABS, Brake lights stay on - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 09-21-2010, 07:24 PM Thread Starter
Date registered: Dec 2006
Vehicle: 2002 E320
Unhappy C230 !997-- ETS, ABS, Brake lights stay on
ETS, ABS and Brake lights stay on after starting the car. They also stay on even when driving. OBDII code read was P0500. This car has 4 speed sensors one on each wheel but no sensor in differential as far as I know. This is what I have done so far:
1. Replaced OEM brake light switch but did not help.
2. Checked resistance of all 4 sensors with DVM and all are close to 1080 ohms. This shows they are normal and not open or short.
So the question is where to look now. What am I missing to find the problem area. Any relays, fuses or other tests on the sensors? Please help. Thanks
Riazcriaz is offline
    ABS, ESP,ETS brake, parking brake lights, no auto-shift, speedo to zero mwaarle W163 M-Class 16 11-28-2015 03:21 PM
    96 SL320 - ABS/ETS dash light on & no brake lights hlavender1 R129 SL-Class 21 05-03-2014 01:29 AM
    W210 '96 230 Abs,Ets and Brake Pad Lights on No Speedo or Odometer.Stuck in Low Gear. bigredmerc W210 E-Class 25 07-17-2012 03:10 PM
    ABS/BRAKE PAD WEAR/ETS LIGHTS ON! HELP? mgill85258 W140 S-Class 4 05-24-2011 09:03 AM
