1995 inline 6 diesel leaking fuel - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 09-21-2010, 07:35 AM Thread Starter
Date registered: Sep 2010
Vehicle: 1976 300SD, 1995 E300D
This car is leaking diesel fuel from the fuel shut off above the fuel filter. I have changed the O-ring while changing the filter but no help.
It is leaking around the brass rod the shut off knob turns. Do I just need to buy this part or is there a fix of some sort; like another O-ring or packing inside or something.
Thanks,
Gus
currently:
76 300D (British red)
95 E300D (metallic charcoal)
2_300_D is offline
post #2 of 6 (permalink) Old 09-21-2010, 08:35 AM
Kajtek1's Avatar
Quoted: 1223 Post(s)
1995 is it non turbo 3 liter diesel?
If it is, the same engine is mounted on 1996-97 models in W210 bodies and we do have the fuel lines replacement well covered in W210 section. General advise is that if the old line shows sign of leaks, the best way is to replace them all since the set cost about $100.
SOV on this engine is below fuel filter, so I am not clear where your problem is.
A picture is worth 1000 words.
Kajtek1 is offline
post #3 of 6 (permalink) Old 09-21-2010, 08:42 AM Thread Starter
OM606 non-turbo
This motor has already had all fuel lines replaced @ the regular scheduled maint. @ 130,000 miles.
The fuel SOV is on top of the nut that tightens down the fuel filter. They are both located on top of the fuel filter housing. There are no lines leaking; it is the valve itself. It leaks around the brass shaft that shuts down the fuel.
Thanks,
Gus
currently:
2_300_D is offline
post #4 of 6 (permalink) Old 09-21-2010, 09:08 AM
Kajtek1's Avatar
So this must be different engine.
I had good luck with finding parts drawing on Russian site.
Go to ??????
enter your VIN number for easy search and look for parts.
Kajtek1 is offline
post #5 of 6 (permalink) Old 09-21-2010, 12:13 PM Thread Starter
I figured it out!
BOTH O rings go on the valve. One above the valve opening and one below. I changed it in near darkness last evening and didn't see the lower O ring on the valve.The smaller O-ring in the filter kit, I thought, was for another application.
No leaks---No worries!
gus
currently:
2_300_D is offline
post #6 of 6 (permalink) Old 01-14-2011, 12:04 PM Thread Starter
This dang thing started leaking again so I bought a new valve. Only Mercedes has it from what I can figure out. Price was 147.00. Not a deal breaker by far but spendy for a part you can put in a letter size envelope. Oh well!
I spend literally hours everyday in my vehicle and drive about 1000 - 1200 miles every week. It's nice to do it in comfort & ease!!
I love these cars,
gus
currently:
2_300_D is offline
    Mercedes E300 Diesel Fuel Leak (OM606) 1995 - Later cdw904 W124 E,CE,D,TD Class 12 08-17-2012 03:23 AM
    Diesel leaking into fuel...? (88 300D Turbo) Chuck Mora W124 E,CE,D,TD Class 0 03-15-2010 02:44 PM
    1995 E300 Diesel Fuel Filters WooDooUK W124 E,CE,D,TD Class 12 01-29-2009 12:05 PM
    W202 C220, 1995 diesel leaking, please help juozukas123 W202 C-Class 3 10-25-2008 04:39 PM
    1995 E300 Diesel Fuel system questions. Gearing up for WVO cdw904 W124 E,CE,D,TD Class 1 07-01-2007 01:43 PM
